Page 2 of 3 1 2 3
Re: Firm Feel p/s box vs stock reman [Re: Kern Dog] #1086399
10/02/11 02:38 PM
10/02/11 02:38 PM
BDW Offline
BDW  Offline
Anyone find a source for the 3/8" ID & 1/2" OD shims needs for this?
Re: Firm Feel p/s box vs stock reman [Re: BDW] #1086400
10/02/11 03:12 PM
10/02/11 03:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Go to Mc Master Carr & type in 3088A466
I/D O/D Quantity Part # Price
3/8" 5/8" 10 3088A466 3.99
The O/D is slightly large but that is the easiest dimension to correct..
Re: Firm Feel p/s box vs stock reman [Re: 1_WILD_RT] #1086401
10/02/11 03:26 PM
10/02/11 03:26 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Got the stage 2 and it is like grandma's Imperial, one finger. They talked me out of the Stage 3, should have went with my first inclination.
Re: Firm Feel p/s box vs stock reman [Re: 1_WILD_RT] #1086402
10/02/11 03:28 PM
10/02/11 03:28 PM
BDW Offline
BDW  Offline
Might be easier to open up ID by .020"?
McCaster #99432A433 or
http://www.smallparts.com/shoulder-lengt...o_pf_B004K1FFVO
Hard to believe there's no off-the-shelf part.
Re: Firm Feel p/s box vs stock reman [Re: BDW] #1086403
10/02/11 03:42 PM
10/02/11 03:42 PM
BDW Offline
BDW  Offline
Best I could find, direct fit, but you need 3 per (0.020" each).
I guess that could be good, you can fine tune it.
Someone send me 4 for finding them.
http://www.amazon.com/Precision-Washer-Bearing-Spacing-Stainless/dp/B004K1FFIC
Re: Firm Feel p/s box vs stock reman [Re: BDW] #1086404
10/03/11 10:26 AM
10/03/11 10:26 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
A few guys have mentioned that copper brake hose sealing washers are great for this.
I should mention that no amount of pressure fiddling will help a box that's simply worn out. In my experience, after about 75K, the "fine edge" is gone!
Rick
Re: Firm Feel p/s box vs stock reman [Re: roe] #1086405
10/03/11 03:58 PM
10/03/11 03:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was thinking about using one of the firmfeel units. I've read good things here about them and have decided that I would probably go with a stage 2 box with them.
My question is for anyone who has used a parts store reman. I've always had good luck with all my other parts store parts and was looking for experiences with the p/s pump. Is it way over boosted like the original I have? Or would it tighten things up a little from my 40 y/o original box? Any experiences? I dont mind paying the $300 for the firmfeel, but also dont mind saving some $$ and buying the $60 reman if it will do the job.
I have only one experience wit ha remaned power steering box , it was a saginaw for a durango , i wasn't impressed wit hit. I'd spend the extra money on new or firm feel.
Re: Firm Feel p/s box vs stock reman [Re: JohnRR] #1086406
10/03/11 06:19 PM
10/03/11 06:19 PM
dracut mass usa
sparcy Offline
sparcy  Offline
dracut mass usa
I have firm feel stage 2 box 11 /16 tie rods late spindles, adjustable upper control arms, plated lower control arms , hotchkiss swaybar. firmfeel adjustable strut rods , firmfeel greasable lca pins with poly bushings notched to hold silicone grease . cop car rotors with calipers mounted to the rear stop flex brake hoses dual diaphame booster 1973 master cly with proportioning valve and metering valve from a T/A (RAMMAN)running dot 5 brake fluid .car out performs my daily driver 2007 magnum . TOOK the car on laborday weekend and my friend drove it and could not get over how well it handled and road .MY customer support from firm was great
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: Firm Feel p/s box vs stock reman [Re: sparcy] #1086407
10/03/11 07:34 PM
10/03/11 07:34 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
, "notched", Is this something new? Care to explain, Any pics?
Re: Firm Feel p/s box vs stock reman [Re: JohnRR] #1086408
10/03/11 07:51 PM
10/03/11 07:51 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I'm needing a box right now for a customers 70 Challenger.
A-1 Cardon is out of stock. Can send in yours and is a 3-4 week turnout. Autozone has them but have had bad luck with theirs in the past.
Think I have the customer talked into a Firm Feel.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Firm Feel p/s box vs stock reman [Re: jcc] #1086409
10/03/11 07:58 PM
10/03/11 07:58 PM
IN
ahy Offline
ahy  Offline
IN
I've got the FF stage II box and love it (70E). I liked it even better when I got caster up to 5-7 degrees. The car had fairly high cornering limits from the get go from springs/swaybar and decent tires. With the caster dialed in and -.75 deg camber limits increased but more noticably, it was just fun to corner. It feels "right". FF was great to deal with and helped set up my suspension plan and trouble shoot a little along the way.
Next refinement? Probably measure and figure out how to correct bumpsteer if needed. I may play with pump pressure also per the MA article.
Re: Firm Feel p/s box vs stock reman [Re: ahy] #1086410
10/04/11 03:53 AM
10/04/11 03:53 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Any experiences with Steer and Gear? They also sell firm feel boxes but are a bit cheaper. They also have a "secret" stage 4 box...
Re: Firm Feel p/s box vs stock reman [Re: DGS] #1086411
10/04/11 04:00 AM
10/04/11 04:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I think Rick covered that quite well about 20 posts above yours...
Re: Firm Feel p/s box vs stock reman [Re: DGS] #1086412
10/04/11 08:37 PM
10/04/11 08:37 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
I had one of their stage 2's before I went with the FF3. The S&G 2 was very sloppy.
I have 50K miles on my FF3. It's still as tight as the day I installed it.
Re: Firm Feel p/s box vs stock reman [Re: ScottSmith_Harms] #1086413
10/04/11 09:38 PM
10/04/11 09:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Once you drive a Firm Feel box you'll never want anything else. I drive a Stage III box and love it! It take a bit more effort than a "one finger" stock PS setup but I like it that way, better road feel is good IMO.
Call Dick Ross and tell him I sent you, he's a good guy!
Naturally I was used to a NOS stock box on my 74 that is not that old which is tight and allows me to steer with eze epecially when I'm sliding the car with rear wheels spinning.
Then I put a stage 2 FF box in my other car with FF upper control arms.
I kind of lost that quick steering control you need when drifting.
The upper arms will completely change the way the car handles for the better because of the added caster.
I didn't really care for the additional stiffness I had with there stage 2 box with all the caster. I had plenty of road feel with the upper arms.
I'm gonna put there upper arms on my 74 with a tight stock box and see before I order my next box for my 3rd and final car. But it'll come from Firm Feel no matter what I buy.
Dick took plenty of time with me on the phone like he must do all day long, good people and great products.
Re: Firm Feel p/s box vs stock reman [Re: Challenger 1] #1086414
10/04/11 10:53 PM
10/04/11 10:53 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
Where do we get these larger 11/16" tie rods (source & part number)?
I replaced my power steering box two years ago with an A-1 Cardone reman unit from Advance Auto Parts. List price was ~$130.00, and I paid ~$100.00 with a discount coupon from their online store.
It is great in that it looks a lot nicer than the old one, it doesn't leak, and it performs as it should.
That being said it is just a stock replacement unit, so over-assist is plentiful. Fantastic for a Sunday cruiser around town, personally I'd like to have a little less assist.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Firm Feel p/s box vs stock reman [Re: daniel_depetro] #1086415
10/04/11 11:03 PM
10/04/11 11:03 PM
IN
ahy Offline
ahy  Offline
IN
For the OS tie rods, your local parts store. A 70's C body from memory is what to ask for. Or you can get nicer/more expensive versions with solid adjusting sleeves from Firm Feel or Mancini.
Re: Firm Feel p/s box vs stock reman [Re: ahy] #1086416
10/07/11 03:20 PM
10/07/11 03:20 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
http://www.mcmaster.com/#round-shims/=ee0sv9
brass bearing shim for 3/16 x 1/2 bearing - .378ID x .498OD x .020
$7.59 for 10
#92409A605
I am going to try these
Steve
Re: Firm Feel p/s box vs stock reman [Re: Strawdawg] #1086417
10/27/11 11:14 PM
10/27/11 11:14 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Did anyone who purchased the FF units get the optional powder-coating? if so - was it worth the $$$?
-C
Re: Firm Feel p/s box vs stock reman [Re: ramman5600] #1086418
10/27/11 11:23 PM
10/27/11 11:23 PM
IN
ahy Offline
ahy  Offline
IN
I didn't... a clean with solvent, a coat of Eastwood self etch primer and a coat or two of SG black had it looking nice in a few hours. It has held up well also. Powder coat isn't the best thing for the mounting locations either unless it is masked; the thick coating reduces with clamp load at the bolted joint.
Page 2 of 3 1 2 3
