Re: Firm Feel p/s box vs stock reman
[Re: BDW]
#1086404
10/03/11 10:26 AM
10/03/11 10:26 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Anyone find a source for the 3/8" ID & 1/2" OD shims needs for this?
A few guys have mentioned that copper brake hose sealing washers are great for this.
I should mention that no amount of pressure fiddling will help a box that's simply worn out. In my experience, after about 75K, the "fine edge" is gone!
Rick
[Re: roe]
#1086405
10/03/11 03:58 PM
10/03/11 03:58 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I was thinking about using one of the firmfeel units. I've read good things here about them and have decided that I would probably go with a stage 2 box with them.
My question is for anyone who has used a parts store reman. I've always had good luck with all my other parts store parts and was looking for experiences with the p/s pump. Is it way over boosted like the original I have? Or would it tighten things up a little from my 40 y/o original box? Any experiences? I dont mind paying the $300 for the firmfeel, but also dont mind saving some $$ and buying the $60 reman if it will do the job.
I have only one experience wit ha remaned power steering box , it was a saginaw for a durango , i wasn't impressed wit hit. I'd spend the extra money on new or firm feel.
[Re: JohnRR]
#1086406
10/03/11 06:19 PM
10/03/11 06:19 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
I have firm feel stage 2 box 11 /16 tie rods late spindles, adjustable upper control arms, plated lower control arms , hotchkiss swaybar. firmfeel adjustable strut rods , firmfeel greasable lca pins with poly bushings notched to hold silicone grease . cop car rotors with calipers mounted to the rear stop flex brake hoses dual diaphame booster 1973 master cly with proportioning valve and metering valve from a T/A (RAMMAN)running dot 5 brake fluid .car out performs my daily driver 2007 magnum . TOOK the car on laborday weekend and my friend drove it and could not get over how well it handled and road .MY customer support from firm was great
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: JohnRR]
#1086408
10/03/11 07:51 PM
10/03/11 07:51 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I'm needing a box right now for a customers 70 Challenger. A-1 Cardon is out of stock. Can send in yours and is a 3-4 week turnout. Autozone has them but have had bad luck with theirs in the past. Think I have the customer talked into a Firm Feel.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: DGS]
#1086412
10/04/11 08:37 PM
10/04/11 08:37 PM
Posts: 2,025 Bucks County, PA
500Stroker
Bucks County, PA
Any experiences with Steer and Gear? They also sell firm feel boxes but are a bit cheaper. They also have a "secret" stage 4 box...
I had one of their stage 2's before I went with the FF3. The S&G 2 was very sloppy.
I have 50K miles on my FF3. It's still as tight as the day I installed it.
[Re: Challenger 1]
#1086414
10/04/11 10:53 PM
10/04/11 10:53 PM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
Where do we get these larger 11/16" tie rods (source & part number)? I replaced my power steering box two years ago with an A-1 Cardone reman unit from Advance Auto Parts. List price was ~$130.00, and I paid ~$100.00 with a discount coupon from their online store. It is great in that it looks a lot nicer than the old one, it doesn't leak, and it performs as it should. That being said it is just a stock replacement unit, so over-assist is plentiful. Fantastic for a Sunday cruiser around town, personally I'd like to have a little less assist.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
