behive valve springs,,some questions
#1086307
10/01/11 02:55 PM
10/01/11 02:55 PM
dartman366
Mt. Vernon, Ohio
I am concidering replacing the rocker's on my engine this winter as part of a winter freshen and upgrade with either Harlan Sharps or T@D's,,my question is do they make or have beehive's that have around 250# on the seat ( i'm not sure of open pressure at this time) so that I can fit un modified/ un special made rockers as I have 1.550 dia springs and the rockers don't have enough built in clearance and have to be re cut/modified for this dia spring, or am I stuck using a std but smaller dia spring like a .470/. 500 if I can get what i need pressure wise.
Re: behive valve springs,,some questions
[Re: POS Dakota]
#1086309
10/01/11 05:32 PM
10/01/11 05:32 PM
dartman366
Mt. Vernon, Ohio
my 250# figure is a little overkill as mine are at 230# as we speak, I tend to figure a little high for springs as they have a tendency to settle in a bit.
[Re: dartman366]
#1086310
10/01/11 10:05 PM
10/01/11 10:05 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
That is true, They will settle in. But I am unsure if there's something out there to accomodate you if your current requirement is up near what you posted. I want to believe there is, but a quick search didnt turn up much better. I think part 265056 from comp will have around 160 lbs on the seat. That was the heaviest one I could find from comp AFAIK. Open was around 400 lbs at 1 inch. I think these figures are based on 1.8 inch installed height. I'm curious to know for sure what pressure difference between a beehive and straight spring is allowable per given application myself and the ALL reasons why.
