porting heads #1086165
10/01/11 01:34 AM
10/01/11 01:34 AM
moscow mills mo
smracing Offline OP
smracing  Offline OP
moscow mills mo
looking to port cast iron 440
heads any tricks or help for a do it yourself guy
other than bowls and gasket matching
mild build
Re: porting heads [Re: smracing] #1086166
10/01/11 07:33 AM
10/01/11 07:33 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Here's a post from one of our members that may help. Just remember to work slowly with the right tools and it can be a very fun and rewarding project. I have an old Hot Rod post I will try to dig up also.
https://board.moparts.org/ubbthreads/show...e=3#Post2885759
http://www.popularhotrodding.com/tech/0610phr_cylinder_head_porting/index.html
http://www.moparmusclemagazine.com/techarticles/5115_cylinder_heads/index.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
