New Cam #1085393
09/29/11 10:16 PM
09/29/11 10:16 PM
Peru
cbarracuda Offline OP
Peru
Installed my new cam shaft today. I had to pulled the motor out. The guys of competition cams told me it needed a little bit of grinding for the roller lifter, so I did just a little bit and everything is fine. This is the first time I install my Cam straight up at 106 degrees, no advance. the roller has 268 duration at 0.50 and 276 exhaust, custome grind. My old cam was a Mopar solid 590 for the last six years. No complains with the Mopar.
Re: New Cam [Re: cbarracuda] #1085394
09/29/11 10:18 PM
09/29/11 10:18 PM
Peru
Peru
one more picture
Re: New Cam [Re: cbarracuda] #1085395
09/29/11 11:52 PM
09/29/11 11:52 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
looks good, i am considering the same swap whats the rest of your combo
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: New Cam [Re: Ian] #1085396
09/30/11 12:05 AM
09/30/11 12:05 AM
Peru
Peru
408 727 8.75 4.30 gears w2 tunel run two holleys 750
Re: New Cam [Re: cbarracuda] #1085397
09/30/11 12:13 AM
09/30/11 12:13 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Why not just run the tie bars facing away from the block? I have run them like that many, many times in a big block. I mean how does the wheel and cam know which way the tie bar is facing? What did Comp say?
Re: New Cam [Re: Bob_Coomer] #1085398
09/30/11 12:20 AM
09/30/11 12:20 AM
Peru
Peru
small block, not a big block the push rod will hit the tie bar diferen angle
Re: New Cam [Re: cbarracuda] #1085399
09/30/11 12:50 AM
09/30/11 12:50 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Gotcha... I figured there was a reason... Nice looking setup...
Good Luck
Re: New Cam [Re: cbarracuda] #1085400
09/30/11 01:22 AM
09/30/11 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good... I glue screen into the intake valley to
cover the holes so if you break anything in the top like
a push rod or rockers or lash caps (if you use them)
so it cant get in the cam or crank and cause more problems
Re: New Cam [Re: MR_P_BODY] #1085401
09/30/11 02:53 AM
09/30/11 02:53 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
what power increase do you think it will make over flat tappet ,what comp has she got ,what has been your ets,
Re: New Cam [Re: MR_P_BODY] #1085402
09/30/11 10:31 AM
09/30/11 10:31 AM
Peru
Peru
Good Idea. what kind of cement? something like JB welding?
Re: New Cam [Re: cbarracuda] #1085403
09/30/11 10:36 AM
09/30/11 10:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I use JB Weld... make sure you run the screen up
the back wall also
Re: New Cam [Re: Ian] #1085404
09/30/11 07:50 PM
09/30/11 07:50 PM
Peru
Peru
power increase maybe 30 to 35 HP. My ET's are low tenths. There is no tracsion on this airport. My comp part number for the Cam is #20-000-9, grind CRS-4207/4205 R 106.0
In your video looks like you are using a 3 links Australian suspension, how well do they work? My friend let me borrow one today and I'm putting it on my car for the next race.
Re: New Cam [Re: cbarracuda] #1085405
10/01/11 01:03 AM
10/01/11 01:03 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
it is a homemade caltrac on it with split mono leafs .there is a 3 link i will post a link to it .
Re: New Cam [Re: cbarracuda] #1085406
10/01/11 01:20 AM
10/01/11 01:20 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Hey Carlos, you will love the roller! Squeeeeze too?
Re: New Cam [Re: 70blackfish] #1085407
10/01/11 01:22 AM
10/01/11 01:22 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
do small blocks need a cam Button?
Re: New Cam [Re: 70blackfish] #1085408
10/01/11 01:43 AM
10/01/11 01:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No we use a thrust plate to control the cam movement
Re: New Cam [Re: MR_P_BODY] #1085409
10/01/11 03:58 AM
10/01/11 03:58 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Re: New Cam [Re: Ian] #1085410
10/01/11 02:11 PM
10/01/11 02:11 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Joose cam?
Re: New Cam [Re: 70blackfish] #1085411
10/01/11 08:12 PM
10/01/11 08:12 PM
Peru
Peru
Hey Jody cam only no squeese
Re: New Cam [Re: Ian] #1085412
10/01/11 08:30 PM
10/01/11 08:30 PM
Peru
Peru
the 3 link tracsion system is in the bigblockdart.com on the tech page rear suspension. Easy to install in a couple of hours
