Page 1 of 3 1 2 3
4 spd 833 help, braking front bearing retainer. #1084833
09/29/11 12:38 AM
09/29/11 12:38 AM
Canada BC
Steve Barton Offline OP
Canada BC
With out ruffling any feathers with my clutch builder, what do you think of this. I have broken two front bearing retainers one write after the other with in a few blocks of driving. I have taken it apart again and found that one of the levers are .200" shorter then the other two on the press plate. In my books that is just not write. It has been said to me that there is in way that this would cause me any trouble with the clutch and no way it would brake the TO bearing slider. here are a few pics, what are your thoughts.
Homepage Pic's http://www.bluemelon.com/dodgeman/ Steve. New best 1.40 60' 9.99 Et 132.8 mph
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084834
09/29/11 12:41 AM
09/29/11 12:41 AM
Canada BC
Canada BC
another pic, you can physically see the difference.
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084835
09/29/11 12:44 AM
09/29/11 12:44 AM
Canada BC
Canada BC
and an other, this is with the clutch ass bolted together as it would be in the car.
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084836
09/29/11 12:48 AM
09/29/11 12:48 AM
Canada BC
Canada BC
this is how the short arm looks.
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084837
09/29/11 12:54 AM
09/29/11 12:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think that 1 arm is hanging up and pushing
sideways when you release the clutch... that pressure
plate would have to go(or change the arm)
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084838
09/29/11 01:03 AM
09/29/11 01:03 AM
Canada BC
Canada BC
I am going to build a new T,O bearing using the big block T,O bearing, it is much larger in diameter, I am just having a sleeve made up to accommodate it on the smaller collar.I believe this will repair the issue with it binding on the short arm and braking the T,O bearing collar. plus I have gone with a billet steal front bearing retainer instead now, but I still don't like the short arm on the clutch.
Re: 4 spd 833 help, braking front bearing retainer. [Re: MR_P_BODY] #1084839
09/29/11 01:08 AM
09/29/11 01:08 AM
Canada BC
Canada BC
this is a new $2500.00 clutch ass.
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084840
09/29/11 01:12 AM
09/29/11 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
IMO... right now you have a $2500 piece of trash...
if that arm is hanging up and pushing on the slider
its going to cause havoc on any bearing
Re: 4 spd 833 help, braking front bearing retainer. [Re: MR_P_BODY] #1084841
09/29/11 10:36 AM
09/29/11 10:36 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Can you loosen the bolt up for the pivot of that 3rd arm on the pressure plate and attempt to slide it inboard any?
Also a really dumb question (assuming with a slickshifted gearset and a $2500 clutch it's been done already), but have you centered the bellhousing to the crank?
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084842
09/29/11 11:19 AM
09/29/11 11:19 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
For $2500. I would expect the arms to be the same length !!!!
One shorter arm will take more pressure to depress. Since its a rotating assembly it would likely start severe harmonics in the release bearing which would transfer to the bearing retainer sleeve. Being cast iron I can see them snapping off. The billet unit will just be a bandaid. I'd get that clutch arm looked at and changed.
Re: 4 spd 833 help, braking front bearing retainer. [Re: Blusmbl] #1084843
09/29/11 11:39 AM
09/29/11 11:39 AM
Canada BC
Canada BC
Yes with in .004"
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084844
09/29/11 09:41 PM
09/29/11 09:41 PM
MI
68shifter Offline
68shifter  Offline
MI
Did you have any luck having the manufacturer take a look at your assembly.
It sure looks like the short lever is riding on the very edge of the to bearing and I cannot see how it wouldn't side load and cause your candlestick problems.
Any drag with clutch disengagement or anything or just when it's "broke". That's a Youngblood unit correct?
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: 4 spd 833 help, braking front bearing retainer. [Re: 68shifter] #1084845
09/29/11 09:58 PM
09/29/11 09:58 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Steve: With the amount of "Free play" we need and travel the t/o bearing does on the retainer, I'm guessing the "side" force from the t/o bearing is breaking the retainer, when you push on the pedal
Remember all the problems I had....I shimmed the fork ahead and all is good.
I think you should do the same.
I can't see how 1 short finger will cause all those issues.
I am surprised you can get away with using a 23 spline t/o bearing though, I was shipped that unit twice and didn't think it would work....maybe that (the lack of surface area vs the 18 spline )is compounding the problem?.
If that bearing won't stay on the fingers where is it going to go...and where will that force go???. something to think about.
I can't tell from the pics but, is there any amount of wear to the fingers?
Ah the joys of running a stick car....
Todd
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084846
09/29/11 10:13 PM
09/29/11 10:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Steve I would send these pics to Rob(it looks like one his plates) because it clearly has one lever too short.This is what is causing the retainer to break without a doubt It is pushing the T.O.bearing off to one side and just plain breaking it off.I have a billet retainer for a 23 spline unit if you need one send me a PM
Gus
64 Plymouth Savoy
Dana 60
Re: 4 spd 833 help, braking front bearing retainer. [Re: 68shifter] #1084847
09/30/11 12:12 AM
09/30/11 12:12 AM
Canada BC
Canada BC
Yes it is robs clutch, he does not want me to send him the clutch back, his opinion is that the short arm has nothing to do with my problem but he is sending me a lever to make me happy.
Re: 4 spd 833 help, braking front bearing retainer. [Re: fourgearsavoy] #1084848
09/30/11 12:23 AM
09/30/11 12:23 AM
Canada BC
Canada BC
Gus
I have sent all these pics and many more to Rob, He is standing his ground saying no way its my problem, he is sending me a lever so that I will be happy even though (it wont help me). I already have a billet retainer to put in this time,as well as a larger T,O bearing, thanks.
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084849
09/30/11 12:35 AM
09/30/11 12:35 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have broken a couple of cast bearing retainers over the years but it was my fault as I dropped the front of the retainer on the bell housing while taking the transmission out without a transmission lift. The 833's are a little heavy while laying on your back trying to remove it and not to get crushed . Billet one now and a transmission jack.
Re: 4 spd 833 help, braking front bearing retainer. [Re: rowin4] #1084850
09/30/11 07:42 AM
09/30/11 07:42 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
How is your pilot bushing in the back of the crank?
Re: 4 spd 833 help, braking front bearing retainer. [Re: Steve Barton] #1084851
09/30/11 09:11 AM
09/30/11 09:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He may not think it's causing the retainer to break but it is definitely an issue because the leverage with the shorter arm is different than the other 2 .
Re: 4 spd 833 help, braking front bearing retainer. [Re: 6PACMAC] #1084852
09/30/11 11:41 AM
09/30/11 11:41 AM
Canada BC
Canada BC
Its a bearing style and it is perfect.
Page 1 of 3 1 2 3
