70 Cuda Rallye Dash Tach #1084668
09/28/11 08:51 PM
09/28/11 08:51 PM
Oklahoma City
Spraygoon Offline OP
Oklahoma City
Got my car running a few days ago and had sent my tach, clock and speedometer to H&H Gary the Tachman. Clock and speedo work great as do all the other gauges, I replaced the current limiter also. The tach reads about 500 high and is VERY slow. I have an FBO ignition with a brand new 6 pack wiring harness. In talking with Gary he says if I send it back he will remove the board he put in and refund my money and thats fine BUT I would really like my tach to work, SO does any one have any suggestions where to send it? Thanks in advance
Paul Reber
Re: 70 Cuda Rallye Dash Tach [Re: Spraygoon] #1084669
09/28/11 08:53 PM
09/28/11 08:53 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Redline installs modern internals.
Re: 70 Cuda Rallye Dash Tach [Re: Spraygoon] #1084670
09/28/11 08:57 PM
09/28/11 08:57 PM
Kirkland, Washington
Pacnorthcuda Offline
The problem with the original tachs is that they have a very HEAVY movement which translated to sluggish response. Back in the day they were OK, but by today's standards they SUCK. I did the upgrade (RPM?) a few years back which helped a bit, but was still unacceptable.
An Autometer tach now resides in front of my 70 'Cuda Tach
Re: 70 Cuda Rallye Dash Tach [Re: Pacnorthcuda] #1084671
09/28/11 10:08 PM
09/28/11 10:08 PM
BDW Offline
BDW  Offline
Surprised anything at all works from the Tach Man.
Guy is a total nightmare, had to get everything he "fixed" redone.
Buyer beware, when someone refuses to accept credit cards because "people have reversed charges for no reason", there's probably good reason to steer clear!
Re: 70 Cuda Rallye Dash Tach [Re: Pacnorthcuda] #1084672
09/28/11 10:09 PM
09/28/11 10:09 PM
Oklahoma City
Oklahoma City
So no one has successfully gotten one to work with a modern ignition or even if it did they still suck??, I wouldn't mind if the response time was slow, I would just like it to read within 200, I am pretty sure the guy I sent it to replaced the "board" but said he had no way to calibrate it or something like that. I had planned on using a shift light anyway, I have an autometer tach that will work a shift light and was just going to mount the tach under the dash or something as the light is on a wire that can be mounted off the tach. I had the tach mounted in front of the clock but I got the clock working so I hate to cover it up.
Re: 70 Cuda Rallye Dash Tach [Re: Spraygoon] #1084673
09/28/11 10:14 PM
09/28/11 10:14 PM
BDW Offline
BDW  Offline
Check RT, they have new circuit boards or you can buy a whole new tach.
http://rt-eng.com/mediawiki/index.php/Dash-Worx_67-74_Tach_kit
Re: 70 Cuda Rallye Dash Tach [Re: BDW] #1084674
09/28/11 10:16 PM
09/28/11 10:16 PM
Oklahoma City
Oklahoma City
Yes that did bother me a bit about the cards. So where did you get yours fixed? Thanks
Re: 70 Cuda Rallye Dash Tach [Re: Spraygoon] #1084675
09/28/11 10:24 PM
09/28/11 10:24 PM
BDW Offline
BDW  Offline
APT fixed my speedo after he screwed it up twice.
http://www.gaugeguys.com/
My tach still doesn't work right, haven't tackled that yet.
I'll probably do the RTE upgrade eventually.
Re: 70 Cuda Rallye Dash Tach [Re: Spraygoon] #1084676
09/29/11 12:03 AM
09/29/11 12:03 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Problem is the OE tach responded to the pulses from the points distributor, quite different for being compatible with a transistor ignition..
The tach's internal circuit board needs updating..
I had RedLine Gauges update my ralley tach to be compatible.
Just my $0.02...
Re: 70 Cuda Rallye Dash Tach [Re: Sinitro] #1084677
09/29/11 09:23 AM
09/29/11 09:23 AM
Oklahoma City
Oklahoma City
Thanks for all the great input, I think I will order the RT kit and put it in my self, it couldn't hurt me to learn a little too.
Paul
Re: 70 Cuda Rallye Dash Tach [Re: Spraygoon] #1084678
09/29/11 12:44 PM
09/29/11 12:44 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had Redline put all new, modern tach internals in my Ralley dash. It's not just a circuit board patch kit. They use all completely new guts. It's fast, accurate and works as good as any new tach out there. It's an excellent way to go. I have MSD and it hooks right up with no adaptors.
Re: 70 Cuda Rallye Dash Tach [Re: jbc426] #1084679
09/29/11 05:34 PM
09/29/11 05:34 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
send it to Redline and get rid of all the stock internals. Did this to both of my cars
Re: 70 Cuda Rallye Dash Tach [Re: THESHAKERPROJECT] #1084680
09/29/11 06:48 PM
09/29/11 06:48 PM
BDW Offline
BDW  Offline
Other than than the circuit board, what other "internals" are there?
Re: 70 Cuda Rallye Dash Tach [Re: BDW] #1084681
09/29/11 08:41 PM
09/29/11 08:41 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The electro-mechanical portion. It looks kind of clock like.
Re: 70 Cuda Rallye Dash Tach [Re: BDW] #1084682
09/29/11 08:59 PM
09/29/11 08:59 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The stock tach consisted of a 2 transistor amplifier driving a meter movement (D'Arsonval moving coil). There were two wirewound resistor trim pots and a handful of large wattage resistors. In short, there was really no reason for it to be very accurate.
I did the RTE (now Dashworx) replacement and then I sent it to him to calibrate it. It is fairly close to my tune up tach. For years, I ran a Heathkit digital tach in the Cuda that was very accurate. The tach in the dash is an analog indicator of a digital signal. Meter ballistics will always delay the indication by several hundred milliseconds. A digital tach should be nearly instantaneous since it just needs to count pulses and divide by time.
Craig
Re: 70 Cuda Rallye Dash Tach [Re: Sinitro] #1084683
09/29/11 09:07 PM
09/29/11 09:07 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Just my $0.02...
The pulse width of the stock electronic ignition was similar in duration to the breaker points ignition and the same voltage. The original factory tachs for each ignition system are identical and equally inaccurate.
Re: 70 Cuda Rallye Dash Tach [Re: denfireguy] #1084684
09/29/11 09:24 PM
09/29/11 09:24 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just my $0.02...
Similar but not the same..
The OE tach will function with a transistor ignition but is highly inaccurate..
The pulses with the transistor ignition system are shorter and faster, thats why the OE tach is way off by 500-1k RPM.. The mechanical meter pointer is slower than a digital display but still the primary issue is pulse response time..
Just my $0.02..
