Pinhole in the oilpan... easy fixes? #1084167
09/28/11 09:26 AM
09/28/11 09:26 AM
o
wunderless Offline OP
o
I recently discovered that I have a pinhole in my oil pan. It is located about 3-4 inches to the left (driver side) of the drain plug. Big enough to leak when warm, small enough that I'm not losing a lot of oil.
I am looking for suggestions on how to repair this without pulling the engine.
It is a 383 in a cuda.
Anyone have some thoughts?
Thanks!
But existing is basically all I do.
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084168
09/28/11 09:39 AM
09/28/11 09:39 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
DRAIN the oil ...and brake-clean the spot A BUNCH of times ... them epoxy the hole.
I did this after I found out the guy who had welded baffles into my pan had put in pin-hole in that.
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084169
09/28/11 09:39 AM
09/28/11 09:39 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
JB weld or epoxy for a temporary fix. If you have a hole from rust it will only get worse. Best bet is to change the pan.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Pinhole in the oilpan... easy fixes? [Re: finadk] #1084170
09/28/11 10:25 AM
09/28/11 10:25 AM
toronto canada
69chargeryeehaa Offline
toronto canada
Best easy fix i ever did was brake cleaner as best as you can, and a very small tiny screw and good RTV....done that on several cars with no leak ever after that. Just cut it short and screw it in. Usually i hit my R/C screw assortment for tiny tiny machine thread screws until i find the right one.
But if you can remove the pan and weld it shut it's the best way...i did this screw on a beater, and it worked for me several times.
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084171
09/28/11 10:28 AM
09/28/11 10:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Unless it's an A body you don't have to pull the engine to pull the pan.
Otherwise as said you can bandaid it but it is caused by rust and is only going to get bigger till you remove the rust and weld it shut .
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084172
09/28/11 10:38 AM
09/28/11 10:38 AM
o
o
Thanks for the answers!
Hadn't thought about the epoxy.
Should have mentioned it isn't cause by rust, best I can see anyway. Just appears to be a small little hole.
I really thought I had to pull the engine to pull the pan. I would like to get it temporarily corrected that allows me to drive it, till I can afford to yank the engine and go through it. It see's limited use in the summers.
Please keep any more suggestions coming. These are very helpful. They are appreciated!
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084173
09/28/11 11:27 AM
09/28/11 11:27 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just use a #6 sheetmetal screw and some rtv,sand the area around the hole then just snug the screw down,its a permenent fix.
Re: Pinhole in the oilpan... easy fixes? [Re: bonefish] #1084174
09/28/11 11:46 AM
09/28/11 11:46 AM
toronto canada
toronto canada
haha, that's what i said in my post above; except you got all fancy with a #6 screw and all!!!
by far the easiest way to fix it...takes 3 mins...
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084175
09/28/11 12:15 PM
09/28/11 12:15 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Seal All. I've used it on a cracked oil pan and applied it when the pan was still dripping and it did the job. Good stuff to keep in the glove box for emergency repairs since it doesn't need a clean and dry surface to stick.
Re: Pinhole in the oilpan... easy fixes? [Re: 446acuda] #1084176
09/28/11 12:37 PM
09/28/11 12:37 PM
dogdays Offline
dogdays  Offline
Any of these fixes will work, or you could use the screw and JB Weld for a permanent fix.
I'd rather see that than trying to weld.
R.
Re: Pinhole in the oilpan... easy fixes? [Re: dogdays] #1084177
09/28/11 04:42 PM
09/28/11 04:42 PM
P
Paul_Fancsali Offline
P
I had a gas tank punctured by trans explosion at the time there were no new ones JB weld bcak in 1988 and never had a issue by the way bottom of the tank. Let set for 24 hours and min temp of no less then 55 degree's
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084178
09/28/11 05:17 PM
09/28/11 05:17 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I fixed the rusty pan on my 84 Ram with the Right Stuff. It had at least a half dozen pin holes on the front of the pan. It's been on there for two years now and no leaks.
Re: Pinhole in the oilpan... easy fixes? [Re: Dabee] #1084179
09/28/11 07:47 PM
09/28/11 07:47 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
I repair pans with my mig all the time. if its real slow, just blast off the area real good and maybe hit it with some 150 grit and spot weld real quick like. Actually just did that on a civic about a week ago.
Re: Pinhole in the oilpan... easy fixes? [Re: ditchdrift] #1084180
09/28/11 08:10 PM
09/28/11 08:10 PM
IN
ahy Offline
ahy  Offline
IN
The epoxy/JBweld method has worked well for me and lasts a good long time if there isn't rust underneath. As posted, drain oil, clean well, sand off paint, clean again and apply the epoxy. You can sand lightly and touch up the paint after the epoxy hardens.
Re: Pinhole in the oilpan... easy fixes? [Re: ahy] #1084181
09/28/11 09:16 PM
09/28/11 09:16 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Clean it up good and solder it with a big electric gun.
Re: Pinhole in the oilpan... easy fixes? [Re: 69chargeryeehaa] #1084182
09/29/11 02:11 AM
09/29/11 02:11 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
great minds think alike.
Re: Pinhole in the oilpan... easy fixes? [Re: bonefish] #1084183
09/29/11 09:00 AM
09/29/11 09:00 AM
o
o
Thank you all for the replies!
My first idea was silver solder. I don't have access to a welder either, sadly, or I think I might have tried that.
I might actually give the screw/epoxy thing a go. Sounds pretty easy and safe.
Will be able to get at it next weekend during Thanksgiving (Canadian), which gives me 3 days to screw it up.
You guys rock!
Re: Pinhole in the oilpan... easy fixes? [Re: wunderless] #1084184
09/29/11 09:25 AM
09/29/11 09:25 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
where is Billy Mays when you need him!
Re: Pinhole in the oilpan... easy fixes? [Re: mikemee1331] #1084185
09/29/11 09:13 PM
09/29/11 09:13 PM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Just get a new pan.
Re: Pinhole in the oilpan... easy fixes? [Re: mikemee1331] #1084186
09/29/11 09:20 PM
09/29/11 09:20 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Thats right, Brutha: MIGHTY PUTTY!
Gotta get it clean though. I like the screw method. I still got a dab of Ultra Copper on my pan, come to think of it. Strange pinhole too, no dent, rust.. no burn on the inside, just a little thumbtack hole on a chrome pan.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
