Page 2 of 3 1 2 3
Re: Most economical method to lower a B-body [Re: redmist] #1083812
09/29/11 07:05 AM
09/29/11 07:05 AM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
Mancini sells lowering blocks for the rear. I used some on my '84 Dodge pick-up after I flipped the axle. They worked fine.
Re: Most economical method to lower a B-body [Re: redmist] #1083813
09/29/11 09:28 AM
09/29/11 09:28 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
Turn down torsion bars, and flip the factory hangers upside down.
this is what i did to my car.
17" wheels. 255/55/17 tires, stock 07 mustang GT tires.
if you lower the torsion bars you MIGHT have problems of to much camber, top of tires leaning in. you can correct with problem solver bushings in the upper arms.
also some people will caution you not to flip the rear hangers. this is because the bolt spacing is slightly different between the top and bottom bolts. you have to die grind the holes a tiny bit to make them fit. some people say this weakens a major structural area. i say poppycock. i did this on my 600+ci hemi car. i have driven it 50,000+ miles without any problems. also the warranty fix for dog tracking volaries was to install shims between the spring hanger and the mount. this weakens it much more than opening the holes a 1/8".
Re: Most economical method to lower a B-body [Re: Mr T2U] #1083814
10/27/11 11:42 PM
10/27/11 11:42 PM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
Any need to run special shocks with a 1-2" drop?
-C
Re: Most economical method to lower a B-body [Re: ramman5600] #1083815
10/28/11 06:38 AM
10/28/11 06:38 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
-C
the bilstiens are valved for the lower height:
http://www.hotchkis.net/rcd_shocks_dodge_b_e_body_4_pack_lowered_cars.html
looks good! same rim and tire combo i'm goin with on my 71 runner - its a great to see what it'll look like - whats your rim backspacing?
Re: Most economical method to lower a B-body [Re: ramman5600] #1083816
10/28/11 06:42 AM
10/28/11 06:42 AM
dangina Offline
dangina  Offline
-C
Re: Most economical method to lower a B-body [Re: ramman5600] #1083817
10/28/11 11:50 AM
10/28/11 11:50 AM
AndyF Offline
AndyF  Offline
I covered this topic in my new B body book.
New spring hangers from FFI or Mancini is the easy way to take care of the rear. You can also re-arch the springs or use a different spring.
Dropped knuckles will work up front or turn down the torsion bars and re-align everything. Firm Feel can get you shorter shocks so they don't act as bump stops.
There is a limit to how low you can go before you need to start spending some money to make it work.
Re: Most economical method to lower a B-body [Re: AndyF] #1083818
10/29/11 03:46 PM
10/29/11 03:46 PM
Michigan, USA
Michigan, USA
What's this book you speak of as I am new the B-body crowd and migt have some interest? Also I just want there to be no gap from the top of the tire to the fender, nit slammed on the ground.
-C
Re: Most economical method to lower a B-body [Re: Mr T2U] #1083819
11/12/11 10:09 PM
11/12/11 10:09 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
...also some people will caution you not to flip the rear hangers. this is because the bolt spacing is slightly different between the top and bottom bolts. you have to die grind the holes a tiny bit to make them fit. some people say this weakens a major structural area.i say poppycock. ...
I agree totally, I just did this to my car (flip the spring hangers) and the stock holes are over large and not a tight fight to the hanger bolts anyways, so the extra 1/8" grinding wont make a boo. Sorry about primer and the bad picks but I lost 2" in the butt. Here is the after pic.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Most economical method to lower a B-body [Re: kilroy] #1083820
11/12/11 10:10 PM
11/12/11 10:10 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I sorry about the crappy picture
The Before pic.
Re: Most economical method to lower a B-body [Re: ramman5600] #1083821
11/12/11 10:48 PM
11/12/11 10:48 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
I don't want to create a low rider, but just drop the car about 2". I know there are a lot of great options for replacement parts to really make the car handle (70 SuperBee), but is there a safe yet economical way to accomplish a 2" drop without spending $2500? Thanks in advance for the advice.
-C
Take a 80mph run at a set of railway tracks like the Dukes boys, repeat if necessary.
A new iron curtain drawn across the 49th parallel
Re: Most economical method to lower a B-body [Re: 67autocross] #1083822
11/13/11 11:00 AM
11/13/11 11:00 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Hes asking how to lower the car, not how to clearance the chassis/exhaust. (not yet at least)
Re: Most economical method to lower a B-body [Re: kilroy] #1083823
11/16/11 10:12 AM
11/16/11 10:12 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Uh... just use the stock leafs and turn the T-bars down...??? Hahahahaha
Seriously, i haven't seen a Mopar yet that hasn't lowered itself at least 2" due to saggy leafs. Just turn the T-bars down.
For a better approach, just use lower profile tires. Thats cheap, and you get better performance tires as a bonus. You can still get 15" V and better rated tires i think. I did this to lower a 71 Fury and a 78 Volare. Both used 50-series 15" rubber on stock tires. The Fury especially sunk a bunch, due to its 78-series stock tire based ride height. Sure, they look goofy with the smaller tires, but i think lowered Mopars look goofy in general, so its probably just me. By the tiny 17" or 18" tires most Mopar guys end up using on the classic rides, id say most people would like the small tire look anyways.
You can lower a stock Mopar up to 3" this way, yet still have a 100% original and untouched suspension. No weird suspension geometry from the usual methods.
Now... if there was only a cheap way to RAISE the rear ov a Mopar without resorting to 2ft long shackles or yummy air-shocks...
Re: Most economical method to lower a B-body [Re: TooMany62s] #1083824
11/18/11 01:26 PM
11/18/11 01:26 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Please do not use lowering blocks.
Re: Most economical method to lower a B-body [Re: kilroy] #1083825
11/18/11 01:28 PM
11/18/11 01:28 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Nice, new springs or stock? What size tires? How about the front? Any over-all shots? Thanks (Burn Notice replica? lol)
Re: Most economical method to lower a B-body [Re: Montclaire] #1083826
11/18/11 09:54 PM
11/18/11 09:54 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
275/60/15 on an 8"rim with 4.5 b/s on the rim. I always thought they looked a little tall with out them being tucked into the fenders like they are now, but I REALLY like the look of them now.
Front I need to lower a little bit more but to do that I gottta fix the crappy local muff shop job on the exhaust (if you want something done right do it yourself) and I need to trim the bump stops a little on the front.
Right now it sits square to the top of the fender openings on the front and back at 26.5".
Springs are just HD springs from about 1999. I havent check the pinion angle yet but I will later. I was good before.
whats with the burn notice replica?
Oh and thanks for the compliment.
Re: Most economical method to lower a B-body [Re: kilroy] #1083827
11/18/11 10:52 PM
11/18/11 10:52 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
front you take out torsion bar adjusters
rear take diff off of springs, flip over and install above springs
this should lower it quite a bit (of course I wouldn't drive it)
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Most economical method to lower a B-body [Re: deansrr] #1083828
11/19/11 12:29 AM
11/19/11 12:29 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Burn Notice - on USA? And no, that's not me in the photo.
Re: Most economical method to lower a B-body [Re: Montclaire] #1083829
11/19/11 12:46 AM
11/19/11 12:46 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Re: Most economical method to lower a B-body [Re: Montclaire] #1083830
11/20/11 12:19 AM
11/20/11 12:19 AM
Michigan, USA
Michigan, USA
Can you explain your thinking?
Re: Most economical method to lower a B-body [Re: ramman5600] #1083831
11/20/11 11:49 PM
11/20/11 11:49 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
*Sigh*
Page 2 of 3 1 2 3
