Type Of Wood For Carb Heat Shield #1083555
09/27/11 07:33 AM
09/27/11 07:33 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am looking at making another carb heat shield and I want to make the next one out of wood. What kind of wood do I need to make this out of?
I was hoping to go by my local Loews or Menards and pick something up and just transfer my existing lexan template onto. I am looking at maybe 1/4" or 5/16" thick for the new shield.
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083556
09/27/11 08:10 AM
09/27/11 08:10 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
do you have a local hobby store near you? if so get a piece of the plywood for models. otherwise I would use some Marine plywood. I would think that a normal board would crack..
I am truckless..
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083557
09/27/11 08:12 AM
09/27/11 08:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why? anyway I'm going to guess you'd want as hard a wood as you can find. The softer woods would (haha) take in moister and possibly soak up the gas.
Coming soon!!!!
Re: Type Of Wood For Carb Heat Shield [Re: Mr.Yuck] #1083558
09/27/11 08:27 AM
09/27/11 08:27 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Why?
I am on my second polycarbonate (Lexan) heat shield and it just cracked over the weekend and I want to try making one out of wood this time. I have a good template that I can just lay over some wood and trace around it and start cutting, but I need to find out what type of wood to use.
Note: I do have a local specialty wood distributor that I have contacted and I am waiting for a reply. But they may not have a small enough piece.
Thanks for the replies.
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083559
09/27/11 09:28 AM
09/27/11 09:28 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
A GOOD QUALITY treated plywood is the ticket
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083560
09/27/11 09:33 AM
09/27/11 09:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Why?
wow never had one crack. Had a 1/2" 4 hole for years on a Supercharged 440 and no issues. You might be able to by a wooden one pre-made. I have seen them but it's been years.
Re: Type Of Wood For Carb Heat Shield [Re: Mr.Yuck] #1083561
09/27/11 09:46 AM
09/27/11 09:46 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
This is not for a carb spacer but for a carb heat shield/carb heat deflector. You can see one of my earlier Lexan shields in this picture. I am on my fourth revision of it now and I need another material. My current one is painted with a black wrinkle finish to match my air cleaner. The paint helps protect it when gas comes out of the bowl during jet changes. The gas is probably what helped cause the cracking with the Lexan.
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083562
09/27/11 10:28 AM
09/27/11 10:28 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ohhhhh... I used the aluminum Holley unit for years. Might still have it someplace.
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083563
09/27/11 10:40 AM
09/27/11 10:40 AM
there was a thread on this way back & a guy posted what to use but I dont remember what it was but it was a specific type that was the best & said that wood was much better than phenolic & solved his problem
Re: Type Of Wood For Carb Heat Shield [Re: RapidRobert] #1083564
09/27/11 10:45 AM
09/27/11 10:45 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am currently receiving emails from a local sawmill. They are helping me with the wood selection for this application. I will give an update once I have decided on a wood that they carry. So far the prices are very cheap and they ship too.
Re: Type Of Wood For Carb Heat Shield [Re: YO7_A66] #1083565
09/27/11 10:51 AM
09/27/11 10:51 AM
Been trying to remember & just coming with "cabinet grade" something. I'd think it'd be easy to do with a table jig saw just trace out the gasket pattern then cut the "square" out on the inside and a little deburring
Re: Type Of Wood For Carb Heat Shield [Re: RapidRobert] #1083566
09/27/11 11:09 AM
09/27/11 11:09 AM
Tehachapi CA
MRBELV2 Offline
MRBELV2  Offline
Tehachapi CA
I think I'd use MDF plywood. MDF - medium density fiberboard. It comes in many different thicknesses. It's very dense, but easy to shape. This material looks very close to the stock one I had on a '78 Powerwagon.
Re: Type Of Wood For Carb Heat Shield [Re: RapidRobert] #1083567
09/27/11 11:17 AM
09/27/11 11:17 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The original 5/16" phenolic spacers under these carbs are 49 years old,never any cracks,with phenolic all you need is the right gaskets.
Also,if you use wood,watch out for Termites!!
Re: Type Of Wood For Carb Heat Shield [Re: 62maxwgn] #1083568
09/27/11 11:43 AM
09/27/11 11:43 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
Re: Type Of Wood For Carb Heat Shield [Re: 360904] #1083569
09/27/11 02:16 PM
09/27/11 02:16 PM
So. Cal. For Now But Texas Bou...
69sixpackbee Offline
I make mine out of Phenolic material such as sanded G10. I have also used black Delrin which, is what I currently have on my BBC.
Bud
Re: Type Of Wood For Carb Heat Shield [Re: 69sixpackbee] #1083570
09/27/11 02:32 PM
09/27/11 02:32 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
After discussing the different wood options, the best option for heat, gas, and not cracking is the Baltic Birch Plywood. I can get a 30" x 30" x 1/4" piece for a whopping $9.00 plus shipping. This will leave me plenty of material left for more changes in the future.
Note: I asked about the Marine Fir Plywood and his response was that the glues are better but the wood is not as hard and it would absorb more fuel. He suggested that I use a urethane coating on the Marine plywood.
The above "Cool Carb" parts appear to be very nice. Thank you for posting that information.
Thanks again for your replies.
