My Monster Mopar Weekend!! KABOOM!! Karnage Inside....
#1082640
09/25/11 10:43 PM
09/25/11 10:43 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
My Son Cory & I took my Road Runner down to Monster Mopar. Had a Great Time!! Josh, you put on a great show!! I ran the Gen 3 Hemi Shootout Class & 11.0 Shootout. Ran a best of 11.05 @ 121.7 for the weekend. Saturday, I ran 11.15, 11.18 & then an 11.34. MPH on the last pass was off by 1.5 mph. I got back to the pits & pulled the plugs. They looked a little lean, so I added fuel. My last pass of the day was the first round of 11.0 Shootout. Did burnout, staged & launched...1st, 2nd then to third, all seemed ok till about 6200 or so, the motor all of a sudden felt like it was on a limiter & before I could react, BOOM!! Thankfully I didn't oil down the track. No holes in the outside of the block, but it wouldn't turn over. So, had no clue what the damage was. When it happened, my Son went to Rick Gorski's & Bondo Bob's pits to see if he could get some help. The staff at IRP towed me to my pits & both Bondo Bob & Rick were right there at my pit as soon as I got there. Bondo went & got a crew to help me get my car on the trailer, as I didn't have a winch. I can't thank them enuff!! And, then Rick came by a little later with some Beer's & hung out and B.S'd. Well, I got it home & got the heads off. I hurt it good. As you can see in the picks the #1 rod, piston & cylinder wall is gone. I have no clue what caused the chain of events & guess it really doesn't matter. Cylinder head is beat up pretty good & there was junk sucked into every cylinder. The biggest problem now is finding a replacement 6.1 block, now that Chrysler is no longer making them. I have a mess on my hands!!
Re: My Monster Mopar Weekend!! KABOOM!! Karnage Inside....
[Re: jcastle1]
#1082642
09/25/11 10:55 PM
09/25/11 10:55 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Steff, sorry to hear your worst fear happened. Hoped the block was still good. Dang. Sorry to see. Great seeing you and your cool son. I'll keep my eyes and ears open for a block.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1082645
09/25/11 11:11 PM
09/25/11 11:11 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
not good at all Steff ! you were so close to your 10.99 pass no problem on the help thats what friends are for i will keep my eye out also on a 6.1 block good seeing ya again Bob
[Re: BobsProFab]
#1082646
09/25/11 11:50 PM
09/25/11 11:50 PM
Wow, that sucks. That's one of my favorite cars on the board too!
[Re: STEFF]
#1082648
09/26/11 12:02 AM
09/26/11 12:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Major BUMMER Steff... hope it isnt as bad as it looks... time for some sleeve replacement... a little touch up on the head and your almost there... good luck buddy
[Re: robnbird]
#1082650
09/26/11 12:52 AM
09/26/11 12:52 AM
Posts: 5,618 long island NY
Ari440
long island NY
can the 6.1s blocks be sleeved ?
1.39 9.85 - 137 mph
[Re: STEFF]
#1082651
09/26/11 01:00 AM
09/26/11 01:00 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I'm assuming that the pistons where stock cast hypertutectic(SP?) pistons, if so then I would assume the valve broke off and destroyed(shattered) the piston, the wrist pin holed the cylinder wall and the rest is history Sorry for your loss. Aren't all the 3G Hemi blocks aluminum? If so sleeving it, as long as there is no damage to the main webs, deck or exteranl cracks in the cooling system, should be easy for a competent automotive machine shop. I like and use ductile iron sleeves in cast iron blocks, I'm not sure if there compatable with aluminum blocks
[Re: Labratt]
#1082654
09/26/11 01:47 AM
09/26/11 01:47 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is the valve spring on that valve still look good? i hear alot about breaking behives that hallow stem is really hallow
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1082655
09/26/11 08:56 AM
09/26/11 08:56 AM
Posts: 2,877 SE Nunya
Bubba
SE Nunya
[Re: sixpackgut]
#1082658
09/26/11 09:50 AM
09/26/11 09:50 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I think his heads were done by Jeff had good springs and retainers. I don't like the valve though, hollow stem, especially production version. Maybe the quality is not there.
Sorry Steff that sucks. Hopefully you can get it back together.
