Re: My Monster Mopar Weekend!! KABOOM!! Karnage Inside....
[Re: MattW]
#1082660
09/26/11 10:14 AM
09/26/11 10:14 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is the valve spring on that valve still look good? i hear alot about breaking behives
that hallow stem is really hallow
I think his heads were done by Jeff had good springs and retainers. I don't like the valve though, hollow stem, especially production version. Maybe the quality is not there.
Sorry Steff that sucks. Hopefully you can get it back together.
they are PAC1218 and there was a rash of pac1518 that broke which is the same spring just coated or something
Chapper, it was a stock 6.1
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1082661
09/26/11 10:20 AM
09/26/11 10:20 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
If the spring caused the damage how would the warranty work?
[Re: sixpackgut]
#1082662
09/26/11 10:25 AM
09/26/11 10:25 AM
Posts: 3,872 Smyrna, South Carolina
STEFF
The Springs, Valve Train in the rocker area & Rockers are all intact, no broken parts & all pushrods are perfect. Yes, the stock Valves are Hollow Stem & yes, the short block was stock.
Jeff did the heads for me & as mentioned PAC springs retainers & locks etc....I believed the hype of how good all the stock components were for the level of power I was making and there are plenty of guys beating the snot out of their stock 6.1's on a regular basis with no issues & there's guys breaking parts as well. It is what it is.......stuff happens. My plan this winter was to put a better rod & piston in it, but the destruction beat me to the punch.
[Re: JERICOGTX]
#1082664
09/26/11 03:07 PM
09/26/11 03:07 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
That's harsh, man. At least you've got a selection of paperweights now! Going to go bigger/better with the rebuild?
[Re: STEFF]
#1082668
09/26/11 07:35 PM
09/26/11 07:35 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
Were you still using the piston squirters (not to start a big debate but I am curious)?
Aluminum 4.15 block with a 3.72 crank from the 6.4 = 402.5 cid. That ought to get you into the tens....
This space not for rent.
[Re: Bill_T]
#1082669
09/26/11 08:07 PM
09/26/11 08:07 PM
Posts: 4,682 On the parachute mount
n20mstr
Steff i really have to apoligize, When you came over and introduced yourself i was thrashing to figure a way to start my car ( Starter relay crapped out....why not its only the original one 38 years young) Any way i would have loved to check out your car in person, i didnt even know you had it there. I was so in a rush since i only got there sat morning about 12:40 and slept at the gate in my truck....We only got to make one pass then went right into elim, we missed our second qualifier Sorry for the carnage also..
....BAD A$$ STREET CAR.....
[Re: Bill_T]
#1082670
09/26/11 08:20 PM
09/26/11 08:20 PM
STEFF
Yes, squirters were intact.
Aluminum Block would be sweet for sure!!
[Re: n20mstr]
#1082671
09/26/11 08:20 PM
09/26/11 08:20 PM
Posts: 614 Michigan
Get-X
Steff, that really sucks bro That's racing though, and sh!t happens. If I hear of a 6.1 block I'll contact you.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: n20mstr]
#1082672
09/26/11 08:23 PM
09/26/11 08:23 PM
STEFF
No worries!! We'll be in the same place some other time, I'm sure.
[Re: STEFF]
#1082673
09/26/11 09:05 PM
09/26/11 09:05 PM
Posts: 2,091 Delray beach, Florida
Performance Only
sorry to see that. i don't run the stock valves in any of those motors. i've seen enough broken stock ones to convince me to change them out.
machine shop owner and engine builder
[Re: Performance Only]
#1082674
09/27/11 09:38 AM
09/27/11 09:38 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Sorry to hear that happened. Having done that with the 64's motor last weekend i feel your pain.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Savoy1964]
#1082675
09/27/11 05:23 PM
09/27/11 05:23 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
Man that sucks Steff With the cam and springs you have I find it hard to imagine the valve would break. do you think it could have floated the valves possibly...Any witness marks on pistons that you can see? Looks like there is a small clean shiney line where the valve may have touched the piston. Sorry again dude
[Re: 340RICK]
#1082676
09/27/11 05:32 PM
09/27/11 05:32 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Sorry to hear that Steff, that is a heart breaker.
[Re: 340RICK]
#1082677
09/28/11 10:29 AM
09/28/11 10:29 AM
STEFF
Sorry again dude
Don't think it went into valve float as it came apart about 6200 & it revved fine thru 1st & 2nd gear to 7000. Talking with Sean (HardcoreB), we both agree that most likely the stock piston came apart & then all heck broke loose.
