Page 2 of 4 1 2 3 4
Re: OK 3th try with the E-85 [Re: ajcasini] #1082214
09/25/11 10:27 PM
09/25/11 10:27 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Well I will run it Fri night with the set up in it and see where we get. and I will report back LOL
Have not run it yet AJ now I got everything fix.
Re: OK 3th try with the E-85 [Re: VernMotor] #1082215
09/26/11 08:19 PM
09/26/11 08:19 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Ok guy My wife read all this and wants to know if I got my distributor lock out and why not and why you guys think I should. So I had to explain what that meant and that I do not. and I not sure I agree with it. so Why would you want more timing at start up with e-85 than gas ?? I have 21 initial and 35 total all in at 1200 rpms
Re: OK 3th try with the E-85 [Re: VernMotor] #1082216
09/26/11 08:36 PM
09/26/11 08:36 PM
NC
440Jim Offline
440Jim  Offline
NC
That sounds fine to me.
Re: OK 3th try with the E-85 [Re: 440Jim] #1082217
09/26/11 09:04 PM
09/26/11 09:04 PM
PA
ajcasini Offline
ajcasini  Offline
PA
When I first converted mine I was setup with same timing curve you had. Ended up locking the distributor out to try it and made no difference. I was launching at 1800-2200 so I was full in after I torques up on the fb. You should be fine with that setup.
Re: OK 3th try with the E-85 [Re: 440Jim] #1082218
09/26/11 09:07 PM
09/26/11 09:07 PM
Johnstown
69dart Online content
69dart  Online Content
Johnstown
I dont understand why you want the timing locked out on E85 but not gas either? Since Jenny foot brakes the car make sure you have hollow squirter screws.
Jamie this is the time to buy - I saw E85 for $3.02 at Polaris today. I'm considering finding a drum to fill up because it was up to $3.50 this summer.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: OK 3th try with the E-85 [Re: 69dart] #1082219
09/26/11 09:54 PM
09/26/11 09:54 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Yes we have the good hollow squirter screws. and yes I need to find a drum also !
Re: OK 3th try with the E-85 [Re: VernMotor] #1082220
09/28/11 04:51 PM
09/28/11 04:51 PM
sweden
sshemi Offline
sshemi  Offline
sweden
dont listen to what jets someone elses different carb has.
If it runs good leave it.
If you start to change air bleeds you will offset the whole fuel curve.
Re: OK 3th try with the E-85 [Re: sshemi] #1082221
09/28/11 10:06 PM
09/28/11 10:06 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i have been running E85 now for three years now with no problems. i have a 3 circuit 1050 set up with the qwk fuel kit. i have went to 99 MJ and bumped up the timing 2 deg over my starting point in 2009. others i have converted also run with no problems. at MMW i ran a best of 9.89 with the trottle loose to run the 10.0 and john cope (CRT) ran a best of 9.94 and jerry hayes (MOPARPITTBULL) ran solid 9.80's with a smaller carb to slow it to the 10.0s. E85 ROCKS.....
WAXER
Re: OK 3th try with the E-85 [Re: VernMotor] #1082222
09/29/11 09:13 PM
09/29/11 09:13 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Ok I started the car up today for the first time in two days..Man this thing is cold blooded . How is the rest of your cars.. is it a little lean ??
Re: OK 3th try with the E-85 [Re: VernMotor] #1082223
09/29/11 09:16 PM
09/29/11 09:16 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
No worse than it was when it was on gas...
Re: OK 3th try with the E-85 [Re: VernMotor] #1082224
09/29/11 09:32 PM
09/29/11 09:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Jamie, what was the ambient temp when you fired it up...
E-85 is REAL cold blooded... I wont even attempt it
if its 45* or lower(maybe closer to 50*) you have to
pump the hell out of it to get it to fire and keep
it lit till it gets some temp into the engine
Re: OK 3th try with the E-85 (update 10-7-11) [Re: MR_P_BODY] #1082225
09/29/11 09:36 PM
09/29/11 09:36 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Did't look at the temp but I will say it was 55-60 degs in the garage..
Re: OK 3th try with the E-85 [Re: VernMotor] #1082226
09/29/11 10:14 PM
09/29/11 10:14 PM
Johnstown
Johnstown
Cold starting is my only complaint with E85. I think that you run the same M1 intake that I run and maybe that contributes to the cold weather start-up issue. Save your starter and go buy several cans of starting fluid. Keep them in the trailer and garage for those 1st starts of the day.
68 Dart - 340
66 Belvedere - 400
Re: OK 3th try with the E-85 update ( 10-7-11 ) [Re: VernMotor] #1082227
10/07/11 11:44 PM
10/07/11 11:44 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
So it was lean.. hesitate.. ran hot.. so I jetted it up to 87-98.. and put .055 squirters in it and move the pump cams to #2 hole. still got some hesitation..so tomorrow I going to put brown cams on it and maybe bigger squirters. might jet the front up some more..But on the good side of it.It has been a while since I drove and I got in the gambler race and won it ! LOL
Re: OK 3th try with the E-85 update ( 10-7-11 ) [Re: VernMotor] #1082228
10/08/11 12:03 AM
10/08/11 12:03 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Making the most out of the little time Jennie let's you drive?
Nice job bud
Re: OK 3th try with the E-85 update ( 10-7-11 ) [Re: WILD BILL] #1082229
10/08/11 12:31 AM
10/08/11 12:31 AM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
I think dad, myself and Bill will be joing you tomorrow, Jaime.
Re: OK 3th try with the E-85 [Re: MR_P_BODY] #1082230
10/08/11 12:42 AM
10/08/11 12:42 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I've started my last Sunday temp. was between 40-45 in the morning u have to pump the h*ll out of it to get it to start and keep it running with the rpm up to get the heat in the motor.
Re: OK 3th try with the E-85 update ( 10-7-11 ) [Re: WILD BILL] #1082231
10/08/11 10:01 AM
10/08/11 10:01 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Nice job bud
I got to keep my 1 win a year streak going !..Jenni can't pick on me to much that way LOL
Re: OK 3th try with the E-85 update ( 10-7-11 ) [Re: VernMotor] #1082232
10/08/11 10:04 AM
10/08/11 10:04 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Nice job bud
What ever you need to tell yourself
Re: OK 3th try with the E-85 update ( 10-7-11 ) [Re: WILD BILL] #1082233
10/08/11 10:06 AM
10/08/11 10:06 AM
tboomer Offline
tboomer  Offline
Bill....Maybe Jenni should drive your car!!
Page 2 of 4 1 2 3 4
