Re: Does this look about right?
[Re: VernMotor]
#1082182
09/25/11 04:19 PM
09/25/11 04:19 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
What are the LED numbers ?
Those are the recorded seconds of the run I believe, but if going by the video it seems like a 22 second pass.
[Re: POS Dakota]
#1082183
09/25/11 05:30 PM
09/25/11 05:30 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
LED #s are run time in seconds. Playback in 1/2 speed makes 11 sec. 22
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: VernMotor]
#1082186
09/25/11 06:32 PM
09/25/11 06:32 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What gear and tyre size do you run. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1082187
09/25/11 07:10 PM
09/25/11 07:10 PM
DragDart360
South Jersey, NJ
3.91 gear, 29 X 10 Hoosier bias ply, 904 w/ std gearing. What should I be looking at as far as converter slip etc. I bought the tach to see if I hit my shift points but I know there's more info there than that.
[Re: emarine01]
#1082189
09/25/11 08:09 PM
09/25/11 08:09 PM
deaks
robin hood country
I would have thought with your motor, 4.30's would be better, you're only goiing through the line at 6200. My 440 is pulling 6500 at the stripe.
