Re: How do I tell if it's a Dana 60 and not a 70?
[Re: DaytonaTurbo]
#1082056
09/25/11 06:16 PM
09/25/11 06:16 PM
Posts: 18,165 Mass
DAYCLONA
Mass
Found an old dodge truck for parts with a Dana in the rear but I'm not sure if it's a dana 60 or maybe a dana 70? How do I tell?
The Dana 60 & 70 use the same cover, but you'll know a 70 when you SEE IT!...Think Dana 60 on steriods ....there's also a Dana 60M that's found under some 3/4 Dodge trucks also
here's a Dana 60
[Re: DAYCLONA]
#1082057
09/25/11 06:17 PM
09/25/11 06:17 PM
Posts: 18,165 Mass
DAYCLONA
Mass
[Re: RUNCHARGER]
#1082061
09/26/11 05:52 PM
09/26/11 05:52 PM
Posts: 2,265 IL
furious70
IL
for $100 I would consider buying that D70 if it's serviceable, still plenty of 1st gen cummins guys who like to do that upgrade! You should be able to flip it.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: DaytonaTurbo]
#1082065
09/27/11 12:03 PM
09/27/11 12:03 PM
Posts: 43,764 Bend,OR USA
Cab_Burge
The dana 70 can be used in a car but they are a lot heavier than you would think. The later(not sure which years to start with, pull one of the axle to see if yours has them or not)Dana 70 had 35 spline axles stock and there are two differrent width carriers in them with two different gear sets, ring gear offset, not like the Dana 60 with 4.56 and above and so on )I had one cut down in a 1963 Belevdere bracket car with 5.13 gears in it, I switch it over to a used 8 3/4 for one race (I broke the 8 3/4 in three runs ) with 4.89 ratio and the car pick up almost a full second Lots of unsprung weight differences between the two I wouldn't do another Dana 70 now for a bracket car or street car, especially not with under 800 HP buy it and swap or turn it and use the money towards a Dana 60
