Starter motor recommendations #1082005
09/25/11 10:25 AM
09/25/11 10:25 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
My new rebuild cranks slow when warmed up. The "old" engine did the same, but not as bad as this one. Yes, I know it is new and will probably loosen up a bit after some more run time. It only has about one hour on it now. Just looking for a reasonably priced HI Torq starter. I should have done this years ago, but what I had worked at that time, now, not so good.. I think I can "overkill" on this one if this price is right.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Starter motor recommendations [Re: 68LAR] #1082006
09/25/11 11:00 AM
09/25/11 11:00 AM
Wisconsin
MagnumExpress Offline
Wisconsin
For the money, Go get a stock late 90's Truck starter, or buy one from Mopar Performance. The 2 are the same. I have used these on motors ranging from 350HP to 1000HP. Also up to 15:1 compression ratio. U will need to clearance starter a little to avoid contact with block, but I think they are a better unit than any aftermerket high dollar piece.
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
Re: Starter motor recommendations [Re: MagnumExpress] #1082007
09/25/11 11:48 AM
09/25/11 11:48 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
MOPAR MINI no shims,etc etc works awesome and cheap
Re: Starter motor recommendations [Re: fishy340] #1082008
09/25/11 12:07 PM
09/25/11 12:07 PM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
I went to a junk yard and got one off a 96 truck just for fit up purposes and to get a application I knew would work and it worked so well its still there only cost 20.00 found that post hit block at freeze plug shortened post to clear works great some of them have a adapter block on them just need to remove it and hook directly to post.Mine had a plug for energize wire soldered that on to my feed wire.
Re: Starter motor recommendations [Re: 68LAR] #1082009
09/25/11 12:08 PM
09/25/11 12:08 PM
NC
440Jim Offline
440Jim  Offline
NC
I have been running the MOPAR (Denso) mini starter from production vehicles for years in my race car. It works great.
Are your headers near starter? Your installation might be heat soaking your starter. A sheet metal heat shield might help your situation.
Re: Starter motor recommendations [Re: 440Jim] #1082010
09/25/11 12:50 PM
09/25/11 12:50 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
The one that I use now is from a '90 Dakota. Maybe it's just plain worn out. It's a pain in the butt to change mine. I don't want to do all of that work for the same result.
Yes they are. The one tube comes within a little less than a 1/4" of the starter. You may be on to something. I had thought that around 1/4" would be enough clearance.
