Re: AAR and T/A Guys Check It Out!!!!
[Re: Troy]
#108212
08/25/08 08:11 AM
08/25/08 08:11 AM
If you block off that nipple you can starve the bowl of fuel.
i checked my center carb this weekend. the line that goes to the fuel bowl vent also goes thru a rectangular port in the center of the metering block and straight to the hole in the front center of the carbs ait horn. so theres a vent there all the time.
I figured that out years ago when I first capped off the vent line on the side. I diidnt want gas to pour out onto a hot manifold if the needle got stuck open.
#108213
08/25/08 10:31 AM
08/25/08 10:31 AM
Posts: 4,051 Connecticut
jeff968
Connecticut
And the test car in question has the 340 six pack decal on the wrong side (left side decal installed on the right side). As for the breather, my T/As, puchased in the late seventies always had the single nipple.
1970 Dodge Challenger T/A
[Re: jeff968]
#108214
08/26/08 12:51 AM
08/26/08 12:51 AM
Posts: 2,340 Lancaster Pa
Transamcuda
Lancaster Pa
Thats kind of common though. Theres a handful of cars known to have this.
[Re: Transamcuda]
#108217
08/26/08 02:29 PM
08/26/08 02:29 PM
how much do these 2 nipple breathers go for? are they being repopped?
