Re: Healthy 383+4-speed+slicks=junk 8 3/4
[Re: jcastle1]
#1081833
09/24/11 11:50 PM
09/24/11 11:50 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yep split the sleeve,lost all the preload then mayhem was introduced ![](/ubbthreads/images/graemlins/no.gif) They all fail eventually ![](/ubbthreads/images/graemlins/shruggy.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: jcastle1]
#1081836
09/24/11 11:57 PM
09/24/11 11:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Another pic of axle splines
For stock axles the splines arent too bad... my go fast axles look worse than that... they took a set and have stayed that way ever since ![](/ubbthreads/images/graemlins/wave.gif)
[Re: jcastle1]
#1081838
09/25/11 12:04 AM
09/25/11 12:04 AM
MR_P_BODY
What do you mean by "split the sleeve"? I don't understand.
Its a 489 case, right... it uses a crush sleeve on the pinion... apply enough load and the pinion will push forwards and crush it more and thats the start of what you have... heavy cars WILL break a 8 3/4... I still use a 8 3/4 but my car is light... with a 1.19 60' ![](/ubbthreads/images/graemlins/wave.gif)
[Re: jcastle1]
#1081839
09/25/11 12:07 AM
09/25/11 12:07 AM
MR_P_BODY
For stock axles the splines arent too bad... my go fast axles look worse than that... they took a set and have stayed that way ever since Not afraid of them breaking off when twisted like that?
Anything is possible... but they have been in there that way for 8 years now ![](/ubbthreads/images/graemlins/wave.gif)
[Re: jcastle1]
#1081841
09/25/11 12:28 AM
09/25/11 12:28 AM
MR_P_BODY
Mike, a friend helped me drill out the 7290 yolk and attached heavier straps and grade 8 bolts/nuts the day before I went to the track. I removed the yolk for drilling. I knew I had the 489 with a crush sleeve. The pig was just freshened with new bearings & pinion seal last fall. I re-installed the yolk and torqued it to 190 lbs. I was told by the person who re-built my pig that he torqued it to 225 ft. lbs. The yolk definately felt different(tighter)after I torqued to 190 I was gonna step it to 225lbs after I reached 190 but stopped because it felt tighter. The next day after driving it to the track,it broke on the starting line after 1 easy pass to break in the new slicks. Do you think I probably crushed the sleeve further,and changed the pre-load? John
If I were to race(or even street drive) the 489 I would go with the solid sleeve... did you change the pre-load... most likely... if I need to pull the yoke I torque it back to spec(or damn close).... JMO on the preload... but either way... a heavy car and 4 speed with slicks and have good bite.... something has to give ![](/ubbthreads/images/graemlins/wave.gif)
