Page 1 of 4 1 2 3 4
Healthy 383+4-speed+slicks=junk 8 3/4 #1081828
09/24/11 11:44 PM
09/24/11 11:44 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Heavy car as well(3840)
Non experienced driver to boot!
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081829
09/24/11 11:45 PM
09/24/11 11:45 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Broke on starting line.
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081830
09/24/11 11:47 PM
09/24/11 11:47 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Richmond 4:10 with cone style suregrip
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081831
09/24/11 11:48 PM
09/24/11 11:48 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Left axle splines twisted.Stock with long wheel studs.
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081832
09/24/11 11:49 PM
09/24/11 11:49 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Another pic of axle splines
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081833
09/24/11 11:50 PM
09/24/11 11:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Yep split the sleeve,lost all the preload then mayhem was introduced
They all fail eventually
Gus
64 Plymouth Savoy
Dana 60
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081834
09/24/11 11:54 PM
09/24/11 11:54 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Scalloping grooves on the carrier is old damage from years ago when the pinion was loose.Had 3:23 gears back then.
New damage is axle and ring gear teeth missing.
Car hooked hard tho....
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081835
09/24/11 11:56 PM
09/24/11 11:56 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
What do you mean by "split the sleeve"?
I don't understand.
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081836
09/24/11 11:57 PM
09/24/11 11:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For stock axles the splines arent too bad... my go fast
axles look worse than that... they took a set and have
stayed that way ever since
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: MR_P_BODY] #1081837
09/24/11 11:59 PM
09/24/11 11:59 PM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Not afraid of them breaking off when twisted like that?
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081838
09/25/11 12:04 AM
09/25/11 12:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I don't understand.
Its a 489 case, right... it uses a crush sleeve on
the pinion... apply enough load and the pinion will
push forwards and crush it more and thats the start
of what you have... heavy cars WILL break a 8 3/4...
I still use a 8 3/4 but my car is light... with a 1.19 60'
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081839
09/25/11 12:07 AM
09/25/11 12:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Anything is possible... but they have been in there
that way for 8 years now
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: MR_P_BODY] #1081840
09/25/11 12:21 AM
09/25/11 12:21 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Mike,
a friend helped me drill out the 7290 yolk and attached heavier straps and grade 8 bolts/nuts the day before I went to the track.
I removed the yolk for drilling.
I knew I had the 489 with a crush sleeve.
The pig was just freshened with new bearings & pinion seal last fall.
I re-installed the yolk and torqued it to 190 lbs.
I was told by the person who re-built my pig that he torqued it to 225 ft. lbs.
The yolk definately felt different(tighter)after I torqued to 190
I was gonna step it to 225lbs after I reached 190 but stopped because it felt tighter.
The next day after driving it to the track,it broke on the starting line after 1 easy pass to break in the new slicks.
Do you think I probably crushed the sleeve further,and changed the pre-load?
John
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081841
09/25/11 12:28 AM
09/25/11 12:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike,
John
If I were to race(or even street drive) the 489 I
would go with the solid sleeve... did you change the
pre-load... most likely... if I need to pull the yoke
I torque it back to spec(or damn close).... JMO on
the preload... but either way... a heavy car and 4 speed
with slicks and have good bite.... something has to give
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081842
09/25/11 12:31 AM
09/25/11 12:31 AM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
jcastle1 I'd be proud of that one maybe a door stop or something for the show and tell LOL you did a fine job on the 383 just need a tougher rear ..
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: Lawn Monkey] #1081843
09/25/11 12:35 AM
09/25/11 12:35 AM
Cincinnati,Ohio
jcastle1 Offline OP
jcastle1  Offline OP
Cincinnati,Ohio
Are you poking fun at me?
I don't quite understand,please explain further.
John
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081844
09/25/11 04:40 AM
09/25/11 04:40 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
He's telling you , be proud, your 383 is a monster that just ate your rearend .
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: jcastle1] #1081845
09/25/11 08:11 AM
09/25/11 08:11 AM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
Not poking fun at all like Remcharger posted you built a monster 383 that something to be proud of .
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: RemCharger] #1081846
09/25/11 01:47 PM
09/25/11 01:47 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Stout engine.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Healthy 383+4-speed+slicks=junk 8 3/4 [Re: OhioMopar] #1081847
09/25/11 01:58 PM
09/25/11 01:58 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yeah, that's kind of a good news/bad news deal. Now you have me thinking about a Dana for my wagon...as in "do it once and do it bulletproof".
Page 1 of 4 1 2 3 4
