'72 340 Demon with V21 and J54 options? #1081442
09/24/11 01:10 PM
09/24/11 01:10 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Does anyone have a pic of a '72 Demon with the J54 and V21 options?
Can anyone help with the fender tag decode as well??
v8x en1
n23 n41 n42 r11 v21 v6x
v1x u g36 j54 m21 m43
fe5 d2x9 tx9 327 486959
e55 d13 lm29 h2b 3*****
Re: '72 340 Demon with V21 and J54 options? [Re: DusterKrazy] #1081443
09/24/11 01:26 PM
09/24/11 01:26 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
v8x en1
Black side and tail stripes
Hood paint
AM radio
duals and tips
Elec ignition
Front hood/surround trim
Drip rail moulding
Sport hood/scoops
Dual Sport mirrors
UIS spec build
Black vinyl roof
Rallye Red
Black bench seat interior/ black upper door frame
SPD 3/27/72
VON 486959
340
3 speed manual trans
Re: '72 340 Demon with V21 and J54 options? [Re: RobX4406] #1081444
09/24/11 01:31 PM
09/24/11 01:31 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
V21 & J54
Re: '72 340 Demon with V21 and J54 options? [Re: NV69B7RR] #1081445
09/24/11 11:54 PM
09/24/11 11:54 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Thanks!
Would anyone know the standard differential ratio with a 3 speed manual transmission?
If the car came with rally wheels, wouldn't that be shown on the fender tag??
Re: '72 340 Demon with V21 and J54 options? [Re: DusterKrazy] #1081446
09/25/11 01:52 AM
09/25/11 01:52 AM
RobX4406 Offline
RobX4406  Offline
3.23
Re: '72 340 Demon with V21 and J54 options? [Re: RobX4406] #1081447
09/25/11 08:46 PM
09/25/11 08:46 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
bump
Re: '72 340 Demon with V21 and J54 options? [Re: DusterKrazy] #1081448
09/25/11 08:55 PM
09/25/11 08:55 PM
Texas
Three40 Offline
Three40  Offline
Texas
3 speed manual would be standard with a 3.23 gear ratio. The wheels would only be on the build sheet they do not list them on the fender tag.The code for rallye wheels on the build sheet would be W21.
Re: '72 340 Demon with V21 and J54 options? [Re: Three40] #1081449
11/12/11 08:32 PM
11/12/11 08:32 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
I found a power steering pump in the car and it doesn't seem to be coded for it?? Any definite way to tell???
Re: '72 340 Demon with V21 and J54 options? [Re: NV69B7RR] #1081450
11/12/11 08:42 PM
11/12/11 08:42 PM
SE Pa.
LimeliteAero Offline
SE Pa.
V21 & J54
Re: '72 340 Demon with V21 and J54 options? [Re: DusterKrazy] #1081451
11/12/11 08:47 PM
11/12/11 08:47 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Broadcast sheet or the window sticker would be the most concrete way to tell. If it was part of a package then it may not be listed on the tag.
Re: '72 340 Demon with V21 and J54 options? [Re: DusterKrazy] #1081452
11/12/11 09:52 PM
11/12/11 09:52 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is my ... Power steering (code S77) was not on fender tag, only the build sheet. Option groups, such as A06 which included power steering, often were on the fender tag as well as build sheet. As already mentioned, the build sheet is best way.
If the car has the Tuff wheel(code S84) that may be an indication of power steering as that was required. I don't think the steering wheel code was on the fender tag.
Attached are 2 pages from the Dodge data book.
