Frame rail fix #1081438
09/24/11 01:05 PM
09/24/11 01:05 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
I have a 70 cuda with a rust cracked frame rail. Should I patch or get a whole new one? Any help suggestions are good
Re: Frame rail fix [Re: paulyvault] #1081439
09/24/11 11:32 PM
09/24/11 11:32 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i would avoid patching/capping one of those
and i would completely replace it...
Re: Frame rail fix [Re: flypaper] #1081440
09/25/11 12:23 AM
09/25/11 12:23 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
pic would help
Re: Frame rail fix [Re: paulyvault] #1081441
09/25/11 01:37 AM
09/25/11 01:37 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
When I had a rusted rear frame issue, I replaced the rail, but I was also replacing all the attaching floors, so that frame replacement was a minor task.
However, if the floors had been in good shape, and the rest of the frame was solid (checking with a hammer for weak spots), I might have cut out the damaged portion and welded in new metal, perhaps adding extra connecting metal inside to help strengthen the joint between the old and new.
Thanks just me. Other opinions may vary.
