Best Holley float bowl gaskets? #1081431
09/24/11 12:31 PM
09/24/11 12:31 PM
Grand Rapids MI
N
N9671X2 Offline OP
N9671X2  Offline OP
N
Grand Rapids MI
Fired up the sixpack bird this spring, center carb leaking like crazy. Pull it and find a new (but don't know how old gasket on the workbench). Change it out, problem solved. Haven't driven it in 2 months, fired it up yesterday and same thing. Is there a "best" gasket available out there? I know inconsistant use is hard on them, but surprised to have this one go bad that quick.
Re: Best Holley float bowl gaskets? [Re: N9671X2] #1081432
09/24/11 12:38 PM
09/24/11 12:38 PM
Locomotion Offline
Locomotion  Offline
I have these "blue" non-stick versions that work well. Don't recall if they are Holley brand or from someone else.
Double check EVERYTHING else. There are a lot of places and reasons for a Holley to leak, not necessarily from the spot you think - debris/old gasket between sealing surfaces, bad bowl screw gaskets, bad inlet fitting gasket or loose.
Re: Best Holley float bowl gaskets? [Re: Locomotion] #1081433
09/24/11 12:48 PM
09/24/11 12:48 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
The blue Holley ones are excellent. Just make sure you get some screw washers too.
Also make sure you get the CORRECT bowl gaskets too....there is a slight difference that won't let the gasket sit properly on the positioning pegs. DAMHIK.
I can take off my bowls many times to do jet changes and the gaskets survive no problem.
Re: Best Holley float bowl gaskets? [Re: Locomotion] #1081434
09/24/11 12:54 PM
09/24/11 12:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
x3 on the blue Holley gaskets
Re: Best Holley float bowl gaskets? [Re: A12] #1081435
09/24/11 01:11 PM
09/24/11 01:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
But you know that is not correct !!
Re: Best Holley float bowl gaskets? [Re: N9671X2] #1081436
09/24/11 01:13 PM
09/24/11 01:13 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Actually never had a problem with bowl gaskets leaking,now with the accelerator pump,that's a different story.
Re: Best Holley float bowl gaskets? [Re: 62maxwgn] #1081437
09/24/11 01:20 PM
09/24/11 01:20 PM
Grand Rapids MI
N
N9671X2 Offline OP
N9671X2  Offline OP
N
Grand Rapids MI
Thanks for posts guys. Bowl gasket did it last time, have not taken it apart since noticing the leak last night, but will keep an eye on other things mentioned. Not ruling out accelerator pump gasket either as it is really coming out of that area.
