833 side cover #1081186
09/23/11 10:27 PM
09/23/11 10:27 PM
Texas US
hemirag Offline OP
hemirag  Offline OP
Texas US
I need to replace the gasket on the side cover on an 833. What will I encounter when I remove the cover? Any pieces going to fall or move out of place?
Re: 833 side cover [Re: hemirag] #1081187
09/24/11 12:15 AM
09/24/11 12:15 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
The forks will rotate down. Not much of a problem.
Re: 833 side cover [Re: GomangoCuda] #1081188
09/24/11 12:21 AM
09/24/11 12:21 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
At least one of the bolts holding the cover is specific to the bolt hole location: it has a clearly visible shoulder.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 833 side cover [Re: EWJ] #1081189
09/24/11 12:39 AM
09/24/11 12:39 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
When you reinstall the cover, and the bolts aren't tight yet, tap it upwards and hold it there until you've tightened a couple of bolts; just a few thousands seem to make 1st/2nd difficult to engage after being in Reverse.
Obviously you don't want the shift levers to rotate out of alignment, check in neutral using a 1/4" shaft or drill bit in the shift tower where it's notched and make sure it slides through the provision in all 3 levers.
Re: 833 side cover [Re: topside] #1081190
09/24/11 12:48 AM
09/24/11 12:48 AM
Texas US
hemirag Offline OP
hemirag  Offline OP
Texas US
Thanks to all for the info
