69 charger oil press gage #1080870
09/23/11 02:44 PM
09/23/11 02:44 PM
union, tenn
tballralph Offline OP
union, tenn
i bought a new rebuilt cluster for my 69 charger everything works but oil press gage.When i turn the key on it goes all the way up but after i start the car it goes all the way down and stays.I did notice it went all the way up at least once while driving it but most of time it did nothing at all.Anyone have any ideas what is wrong? Help ball boy
Re: 69 charger oil press gage [Re: tballralph] #1080871
09/23/11 04:22 PM
09/23/11 04:22 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I would change the sender out and if that didn't fix it you may have to get a new gauge.
Re: 69 charger oil press gage [Re: okie] #1080872
09/23/11 07:14 PM
09/23/11 07:14 PM
union, tenn
union, tenn
I have changed my sending unit and tested my gage with 5 volt batt. you think it could be my gage? I may have to send it back if thats the case but i thought if the batt. test was good the gage was.But what else could it be huh?
Re: 69 charger oil press gage [Re: tballralph] #1080873
09/23/11 08:51 PM
09/23/11 08:51 PM
okla.
O
okie Offline
okie  Offline
O
okla.
You can ground your wire at the sender just for a min. just don't leave it on there very long. Turn your key on and it should move over. I think you can take a test lite and put on the sender wire with the switch on and it should flash. I know on mine I ended up and just bought a new gas and oil pressure gauge. I would expect it to be the gauge. Good Luck Ronnie
Re: 69 charger oil press gage [Re: okie] #1080874
09/24/11 09:14 AM
09/24/11 09:14 AM
union, tenn
union, tenn
I can not test it that way for when i turn the key on it goes all the way over and stays until i start the car and then it would go all the way down.Itested all gages with 5 volt batt by touching it to the back of the gages they all moved over except temp gage witch i re placed and now works.I think it moving over with key on is a clue but not to me.I bought the rebuilt cluster from a guy named bob on line with a 96.6 rating he has done fixed temp gage and tryed to fix speedo once im just geting ready to send speedo back again thats why im making sure i do not need to send oil gage.
Re: 69 charger oil press gage [Re: tballralph] #1080875
09/24/11 10:00 AM
09/24/11 10:00 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Not trying to be funny but do you have the correct sending unit?
Cars with the gauges used a different one, looks like a bell sort of maybe 2" dia X 3" tall.
Maybe thats it
Re: 69 charger oil press gage [Re: idrivevintage] #1080876
09/24/11 10:25 AM
09/24/11 10:25 AM
union, tenn
union, tenn
Yes, i got the wrong one the first time.I first thought ground problem but i do not think the other gages would work if so.The monting board looks o.k. to. I still think the way it pegs out and stays when key is on is a clue.
Re: 69 charger oil press gage [Re: tballralph] #1080877
09/24/11 12:02 PM
09/24/11 12:02 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
When the wire is off the sender, what does it do with key turned on?
Re: 69 charger oil press gage [Re: tballralph] #1080878
09/24/11 12:22 PM
09/24/11 12:22 PM
My Garage / Museum
Chrysler Plant
Chrysler Plant
My Garage / Museum
By chance did you use Teflon tape on the sending unit during the install? If so that might be keeping it from being grounded
hope you get it working
Re: 69 charger oil press gage [Re: idrivevintage] #1080879
09/24/11 01:23 PM
09/24/11 01:23 PM
union, tenn
union, tenn
It does nothing with wire off.And no tape.
Re: 69 charger oil press gage [Re: tballralph] #1080880
09/24/11 01:32 PM
09/24/11 01:32 PM
chicagoland,usa
chicagoland,usa
Still sounds like a sender-switch issue.
Re: 69 charger oil press gage [Re: buildanother] #1080881
09/24/11 02:29 PM
09/24/11 02:29 PM
union, tenn
union, tenn
With due respect, it did the same thing with old sending unit i already replaced. I guess i might have to get new gage i do not know what else to do. Thanks.
Re: 69 charger oil press gage [Re: tballralph] #1080882
09/24/11 03:01 PM
09/24/11 03:01 PM
sounds like a wiring loose connection/continuity/dead short prob if it does that with the wire off of the eng sender because with no continuity to the sender/ground on the block the gauge should never move
