if you want just to get rid of louvers, you can, but then will requiere some home made fillers or frame to make it look smooth and nice like this:
The frame replaces the louvers assembly and attaches on same locations and is not more than a small frame to get all the glass edge around covered. Its a plug and play job.
Thats a M07 option only available on 74s ( mostly found on Spring Specials models ). Its a fixed opera window without louvers.
these are not easy to find though, and I guess for a full good look will require to remove inner and outer louvers and of course get the replacement frames inside and outside
You can also cut the louvers gills and refinish the cut areas... or home made the frames
