One warning new about HR688 ( this is sad to me ) #1080850
09/23/11 01:43 PM
09/23/11 01:43 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
This is really very sad to me talk about this but is something that need to be warned.
the HR688 FBO module is not more than a GM HEI module built in on a fancy Mopar disposition box
more info here:
http://www.dodgecharger.com/forum/index.php/topic,84811.0.html
that is something what IF YOU REALLY WANT, can be done by yourself on any damaged stock box you have around, but definitelly not paying more than the GM HEI module itself at your local store.
Re: One warning new about HR688 ( this is sad to me ) [Re: NachoRT74] #1080851
09/23/11 05:42 PM
09/23/11 05:42 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Amazing...Thanks for the heads up..
Re: One warning new about HR688 ( this is sad to me ) [Re: screamindriver] #1080852
09/23/11 06:33 PM
09/23/11 06:33 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Hey, I just did this swap for about $40 on my slant six Valiant!
Slant Six Upgrades on my 1967 Plymouth Valiant Coupe
Re: One warning new about HR688 ( this is sad to me ) [Re: rabid scott] #1080853
09/24/11 12:13 AM
09/24/11 12:13 AM
Valencia, España
Valencia, España
yes that's something has been done for years, and in fact you can make it inside an old ECU box you have around, removing everything from inside and attaching the GM HEI module inside the Mopar Box to the 4 pins to keep stock look ( what it is making in fact FBO with the new box, but CHARGING WHAT THEY CHARGE FOR THE FANCY BOX )
