Adjustable idle air bleed tuning questions. #1080824
09/23/11 11:54 AM
09/23/11 11:54 AM
Rancho Cucamonga,Ca
3
392charger Offline OP
Rancho Cucamonga,Ca
I am clueless on how to tune the idle air bleeds. Proform main body on a 750 double pumper/440 auto. Carb came with a ton of parts I bought so I have no history other than it looks new. Seems the bleeds are holley jets... and huge for air bleeds! 75's on the outer corners and 35's on the inners, (hope that makes sense). Is that right? Can't get it to idle correctly without sticking a tooth pick in two of the outer bleeds. What's the deal? Thanks for any info/help
Re: Adjustable idle air bleed tuning questions. [Re: 392charger] #1080825
09/23/11 12:10 PM
09/23/11 12:10 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Can't get it to idle correctly without sticking a tooth pick in two of the outer bleeds.""
- If you are making the IAB's smaller and getting a better idle (no other change), then you are lean and need to rotate the metering screws outward to richen up the idle circuit.
One reason for changing the air bleeds sizes would be if your metering screws are only out "less" than about 1/2 turn at best idle vacuum. Using larger IAB's would help move these outward at best idle vacuum.
Another reason would be to lean/richen (tweak) the transition circuit during cruise.
