In case this may be of interest to anyone, here are the details of my rebuild-in-progress RB 452 and the new RB 451 build-up.
The 452 is a basic freshen-up of the MoPig's engine in conjunction w/ switching from the old Stage VI heads and solid flat-tappet cam to ported Victor heads and a small roller.
The 451 is a new engine I'm almost done collecting parts for, since the 452 is now on it's 4th (re)build... and nothing lasts forever.
![](/ubbthreads/images/graemlins/puke.gif)
Neither one is anything special; the 452 has already been the foundation for a streetable 10-second combination. The main differences are the 451 is getting a stronger crank and will have a lighter bob weight by about 140 grams. Performance-wise, I'd expect they'd be virtually identical, but I'm hoping the 451 will benefit from improved durability as I add another 40+ HP to the equation.
*** 452 ***
Block
- '73 OEM 440
- Pro-Gram cross-bolted main caps on #2-4
- .060" oversize + re-hone
- bushed lifter bores
- zero decked
Pistons
- custom 4.380" Ross flat-tops ("replicas" of original build's JEs)
- 6 cc valve reliefs
- 648 grams + 154 grams pin
- piston to wall clearance .006-.0065" after re-hone
Rings
- Mahle 1/16", 1/16", 3/16" file-fit w/ standard-tension oil (replacing the Total seal "Gapless" top ring set used previously w/ inconclusive results)
- top gap .020", 2nd gap .024"
Rods
- Eagle 6.76" x .990"
- 895 grams
- new ARP 8740 bolts
Bearings
- FM Comp Series 3/4-groove mains
- FM Comp Series rods
- Main & rod clearance .0027-.0028"
Crank
- OEM 440 forged cut to .010"/.010" under
Bob weight ~ 2500 grams
*** 451 ***
Block
- '71 OEM 440
- Plate-style aluminum main caps; TBD on whether a CRE girdle will be used, too
- .055" oversize
- standard lifter bores (not bushed)
- deck height .005" (pistons down .005"), TBD on whether I have it cut again for zero deck or run something like a .036"-thick gasket to keep the quench around .040"
Pistons
- CP flat-tops
- 632 grams + 141 grams pin
- piston to wall clearance .004"
Rings
- Total Seal conventional 1/16", 1/16", 3/16" file-fit w/ Napier 2nd and 18# oil ring tension
Rods
- K1 6.76" x .990"
- 841 grams
- ARP 2000 bolts
Bearings
- Clevite H-series narrowed
- Main & rod clearance .0028-.0029"
Crank
- Eagle 4340 3.75" stroke cut .010"/.010" under
Bob weight ~ 2360 grams
![](/ubbthreads/images/graemlins/3_2_116.gif)
