what sway bar in an E-body with narrower rearend? #1079109
09/20/11 08:09 AM
09/20/11 08:09 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, am installed a 65~67 b-body width rearend into my AAR, obviously the sway bar will no longer fit as original. Do any type of adapter plates exist for such applications (or do I just fab something up)? Or do I use a b-body sway bar?
Thanks for any input!
Re: what sway bar in an E-body with narrower rearend? [Re: kielbasa] #1079110
09/20/11 08:24 AM
09/20/11 08:24 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I don't think the mounts change? You didn't move the leaf springs did you?
Re: what sway bar in an E-body with narrower rearend? [Re: Challenger 1] #1079111
09/20/11 08:53 AM
09/20/11 08:53 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
yes, leaf springs are moved in.......
Re: what sway bar in an E-body with narrower rearend? [Re: kielbasa] #1079112
09/20/11 08:56 AM
09/20/11 08:56 AM
Cincinnati, Ohio
Cincinnati, Ohio
Mine are moved in 3/4" on each side on both cars and the sway bars fit fine on both my cars. You don't have do anything imo.
Picture of mine with the springs moved in 3/4" on each side.
Re: what sway bar in an E-body with narrower rearend? [Re: Challenger 1] #1079113
09/20/11 10:14 AM
09/20/11 10:14 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
hmmm, i have dr. diffs relocating kit, i assume it moves each leaf 3/4" just like yours, but unless i bend the sway bar links, i just don't see how it can fit.....is yours an aftermarket sway bar?
thanks for the pic.
Re: what sway bar in an E-body with narrower rearend? [Re: kielbasa] #1079114
09/20/11 10:36 AM
09/20/11 10:36 AM
Cincinnati, Ohio
Cincinnati, Ohio
I think his moves them in 7/8", I still don't think it is a problem.
My sway bar is a Firm Feel bar, stock size.
Re: what sway bar in an E-body with narrower rearend? [Re: Challenger 1] #1079115
09/20/11 11:38 AM
09/20/11 11:38 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
i suppose i could [Edited by Moparts - Family Friendly Site - Keep it clean] the sway bar links, but then they would be crooked.
do you have a b-body sway bar?
i think the easiest and most effective would be to would be fab up offset links i guess. i suppose i should search to see if these exist - hard to imagine i'm the only person that's run into this.
Re: what sway bar in an E-body with narrower rearend? [Re: Challenger 1] #1079116
09/20/11 11:42 AM
09/20/11 11:42 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There's a guy over on CC.com who modified his original brackets so the end links weren't angled. He cut open the brackets and added material to the outside. That allowed him to drill a new hole for the end links. I can try to find his post.
Re: what sway bar in an E-body with narrower rearend? [Re: burdar] #1079117
09/20/11 11:47 AM
09/20/11 11:47 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
When I swapped to a '70 B body rear in my Cuda, I strategically welded some studs to a metal shop table to hold the sway bar in place, got a long pipe to slip over the end and bent the ends in by hand. You'll need someone to secure the sway bar at the table while you tug on the ends. I think I bent each end inward an inch. It took me about 20 minutes.
Re: what sway bar in an E-body with narrower rearend? [Re: PAINT IT BLACK] #1079118
09/20/11 11:52 AM
09/20/11 11:52 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here's the link to his post. His modification to the brackets is twards the bottom of the page.
http://www.cuda-challenger.com/cc/index.php?topic=44869.120
Re: what sway bar in an E-body with narrower rearend? [Re: burdar] #1079119
09/20/11 09:36 PM
09/20/11 09:36 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you arent afraid of getting teased check out an F150/250 rear sway bar--it even has bolt off plates to take from the donor truck---put some on a 64 savoy once---bob
Re: what sway bar in an E-body with narrower rearend? [Re: kielbasa] #1079120
09/20/11 09:45 PM
09/20/11 09:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I guess if i wasn't so lazy tonight we coul;d calculate the change in roll resistant by moving the springs 1.625" against the original measurement of 46"? Assuming no other changes were made, such as track, ride height, shocks, springs, spring bushings, front sway bar/suspension, why not just try it before figuring out the revised rear sway bar. Nothing says you have to have a rear sway bar, they really are more for balancing the front to rear roll resistance anyway.
Re: what sway bar in an E-body with narrower rearend? [Re: jcc] #1079121
09/20/11 10:09 PM
09/20/11 10:09 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
I believe the Hotchkis rear bars offer adapters to work with narrowed rears
Steve
Re: what sway bar in an E-body with narrower rearend? [Re: jcc] #1079122
09/20/11 10:49 PM
09/20/11 10:49 PM
Cincinnati, Ohio
Cincinnati, Ohio
Bending the bar I think is better than making silly axle brackets to fit.
7/8" on each side is not enough to make a big difference. Your just add weight to the back of the car and it may not be strong enough(the modified spring bracket and flex) Put the car together and get under there and then see if you think it is a problem, it wasn't for me and I bet if I never told you you would never even notice it under my rear end.
And it sure as hell don't hurt performance because my 71 handles twice as good as my 74.
My again.
Re: what sway bar in an E-body with narrower rearend? [Re: Challenger 1] #1079123
09/20/11 10:55 PM
09/20/11 10:55 PM
BDW Offline
BDW  Offline
I also used my stock e-body sway bar with the Dr Diff 1" offset set-up. Bolted up fine, visually it doesn't look so great with the links at an angle. I'm sure there's not really any significant performance difference.
Re: what sway bar in an E-body with narrower rearend? [Re: BDW] #1079124
09/22/11 03:01 AM
09/22/11 03:01 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Did the same thing about 15 years ago on my '73.
Took some 3/8" X 1&1/4" bar stock (I think it was the rear front spring shackle from a ramcharger cut in two)
and bolted it to the original bracket with a ball joint bolt (like 3/4" dia) and drilled a new hole 3/4" inboard.Been on there forever, does NOT move, problem solved.
Re: what sway bar in an E-body with narrower rearend? [Re: kielbasa] #1079125
09/22/11 01:04 PM
09/22/11 01:04 PM
PA
noplanb Offline
noplanb  Offline
PA
Dick Ross at Firm Feel made me an E-body bar to work with B-body width perches. Using it with Cass' offset kit (65-67 B-body Dana on 1972 Cuda). Not sure if the B-body bar has the same contours as the E. I had to get a new bar anyway.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: what sway bar in an E-body with narrower rearend? [Re: noplanb] #1079126
09/22/11 01:48 PM
09/22/11 01:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The addco, helwig, and hotckis rear sway bars will work. The helwig and hotckis dogbone connector links may need attention.
I know Hotchkis has a special bolt for clearence on the rear sway bar connector for moved springs. But I don't remember what the exact moved over amount was.
Re: what sway bar in an E-body with narrower rearend? [Re: noplanb] #1079127
09/22/11 02:09 PM
09/22/11 02:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I got the same thing on my e-body with b-body rear and Caltracs. I've trimed that long link bolt since this pic.
Re: what sway bar in an E-body with narrower rearend? [Re: jbc426] #1079128
09/22/11 07:09 PM
09/22/11 07:09 PM
BDW Offline
BDW  Offline
Under ideal conditions the sway bar end would be directly over the bracket to transfer 100% of the force downward.
With the sway bar moved 1" over there with be lateral force that can be broken down into a vertical and horizonal components.
I measured the links to be 5" long, so if I did my math right, the downward force is reduce to effectively 4.9", which is only a 2% reduction in downward force.
No problem that I can see, bolt it up as is and save your money.
