Pistons: Ross Forged Vs. New KB Forged ICON FHR
#1078860
09/20/11 01:58 AM
09/20/11 01:58 AM
Posts: 712 California
BigDaddy440
California
ROSS VS KB Forged ICONS
I'm getting ready order flat top pistons for my 440. I want forged units, and I want them as light as possible for my dollar. I can get either set for about $430.
The Ross units are 658 grams / slug.
The KB ICONS are 528 grams / slug.
The Ross units have thinner 1/16" rings whereas the KB ICONS have thicker 5/64 Rings.
I know Ross has a good reputation, but the ICONS seem to be getting good reviews and they're lighter weight. I believe the ICONS only have a forged head where the Ross are a true forged piston.
My applications is street / strip, no power adders.
Thoughts? Experiences with either?
Thanks, Dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Pistons: Ross Forged Vs. New KB Forged ICON FHR
[Re: rebel]
#1078863
09/20/11 08:28 AM
09/20/11 08:28 AM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
You might want to be sure both those weights are either with or without the pin. Apples to apples you know.
[Re: rickstershemi]
#1078865
09/20/11 09:29 AM
09/20/11 09:29 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
never heard of a partially forged piston.
my guess is the ross weight it w/pin, the icon, w/o pin
[Re: patrick]
#1078866
09/20/11 11:09 AM
09/20/11 11:09 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Call Diamond pistons and don't look back. Great people and service. ![](/ubbthreads/images/graemlins/thumbs.gif)
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
[Re: BigDaddy440]
#1078867
09/20/11 11:14 AM
09/20/11 11:14 AM
BradH
I don't know what the FHR-series Icon is, but the "race" piston they offer is a good part. I had a set, but ended up selling them because the block wasn't machined correctly for their bore size and I had to get it taken out to the next oversize.
The FHR weight you provided sounds waaaay too light to me for a stock-stroke RB application. The 822-040 Icons I had -- despite that they were advertised as being 686 grams + a 141 gram pin -- actually weighed 704 grams and had a 157 gram pin. The comparable Ross piston & pin combination is about 50 grams lighter.
I think they're both a good piston, FWIW, and am using Ross in my current rebuild.
[Re: Guitar Jones]
#1078868
09/20/11 11:29 AM
09/20/11 11:29 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
The weight is without the pin on the ICON. They are one of the best pistons out there for the money though. They're in my engine too.
[Re: patrick]
#1078869
09/20/11 11:30 AM
09/20/11 11:30 AM
POS Dakota
detroit, mi
Me neither...that struck me as odd. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: BigDaddy440]
#1078871
09/20/11 12:09 PM
09/20/11 12:09 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Icon IC836 709 + 141 pin Icon IC822 868 + 141 pin Icon IC968 685 + 190 pin Icon IC837 709 + 141 pin
RIP Monte Smith
[Re: BigDaddy440]
#1078872
09/20/11 02:33 PM
09/20/11 02:33 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
As mentioned by others, I don't think those weights are correct.
Icon is a good piston for the money, but they do tend to weigh more than a equivalent piston from Ross, Diamond or SRP. Been a while, but on the last 440 I built, they were about 50 grams heavier than those others named for a 440 flat top.
Just got done building a small block stroker and I found SRP's offered the best bang for the buck in my combination.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1078873
09/21/11 12:46 AM
09/21/11 12:46 AM
BigDaddy440
California
Thanks for the responses.
I'm taking the weights straight off the notes from the summit and jegs websites, so YES, there could easily be an error.
The ICON piston is PN: IC9953-30, according to Summit's notes, the piston itself weighs 528grams & and the pin weight is 102g, so that's 630grams total IF the notes are correct.
The Ross piston is PN 99539, and according to Jegs' notes, the piston's weight is 658grams (Pin not mentioned). Summit doesn't list the weight of the Ross 99539 piston on their site. So I could assume the 658grams is WITH the Pin, making it only slightly heavier than the ICON units, OR 658g is piston only, and Summit's weights for the ICON piston is way off.
** According to Jegs' website the ICON piston is 692 grams, doesn't say if that is with or without the pin.
I guess I just need to call KB and Ross to get the actual weights. -dan
[Re: dodgeboy11]
#1078876
09/21/11 03:53 AM
09/21/11 03:53 AM
Posts: 2,141 junction city oregon
viperblue72
I don't think all the icon weights are advertised correctly. I noticed they are very inconsitent weights as advertised. The ross pistons are much lighter. You can look on the ross website it lists every detail about every piston. I never heard anything bad about ross pistons but a few of the above posts. I would like to hear more specifics.
