charger 4 speed transmission ID help #1078575
09/19/11 08:43 PM
09/19/11 08:43 PM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
69 charger RT/SE trans has these numbers on it, can anyone tell me what it is from.
oAI16671
PP8332946 005
Re: charger 4 speed transmission ID help [Re: buck0123] #1078576
09/19/11 09:12 PM
09/19/11 09:12 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
PP = new process
833 = model
2946 = build date is Thursday, August 21, 1969
More info available such as assembly plant etc.
Try Brewer's site or simply google
Re: charger 4 speed transmission ID help [Re: 68CoronetRT] #1078577
09/19/11 09:57 PM
09/19/11 09:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
0A - 0 is the model year, 1970. A is the assembly plant for the car, Lynch Road.
They built B-Bodies only for the 1970 model year, but no Chargers.
Re: charger 4 speed transmission ID help [Re: Alaskan_TA] #1078578
09/22/11 11:19 AM
09/22/11 11:19 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
Can anyone tell what kind of b-body this came out of by the last numbers of the vin?
Re: charger 4 speed transmission ID help [Re: buck0123] #1078579
09/22/11 11:42 AM
09/22/11 11:42 AM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
If it is from a 69 then it should have the vin stamped on it.
Re: charger 4 speed transmission ID help [Re: srunge55] #1078580
09/22/11 12:29 PM
09/22/11 12:29 PM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
It is not the original transmission. It only has part of a vin number on it. 0AI16671
PP8332946 005
So It is out of a 70 b-body but I was trying to figure out what b-body.
Re: charger 4 speed transmission ID help [Re: buck0123] #1078581
09/22/11 12:36 PM
09/22/11 12:36 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
PP8332946 005
The Lynch Rd. plant built all 70 B body styles except the Charger in 1970. Could be from any body style made there....impossible to tell unless you match up the VIN # to a known car.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: charger 4 speed transmission ID help [Re: 70gtx440dana] #1078582
09/22/11 12:56 PM
09/22/11 12:56 PM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
Anyway to tell if it is 18 or 23 spline shaft with out taking it out of the car??
Re: charger 4 speed transmission ID help [Re: buck0123] #1078583
09/22/11 01:28 PM
09/22/11 01:28 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
pull the inspection plate and see if its course or fine splines.
Re: charger 4 speed transmission ID help [Re: ditchdrift] #1078584
09/22/11 02:49 PM
09/22/11 02:49 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The car would've been scheduled to be built the first week of September 1969.
Closest I have any info on is a 383 Road Runner 75 assigned VINs earlier & a 383 Super Bee 600+ VINs later.
Re: charger 4 speed transmission ID help [Re: srunge55] #1078585
09/22/11 03:34 PM
09/22/11 03:34 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Not true , I have ever only seen early 69 engine and transmissions with the full VIN , early being assembled before Jan. 1, 69, it was spotty as to what did and didn't get them.
Re: charger 4 speed transmission ID help [Re: buck0123] #1078586
09/22/11 03:36 PM
09/22/11 03:36 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Unfortunately on a 70 trans the only way to tell is if you can see the casting number on the bearing retainer , pull the lower bellhousing shield and see what you can see.
