School me on Tubular Front ends #1078342
09/19/11 04:55 PM
09/19/11 04:55 PM
Milwaukee WI
R_Blaha Offline OP
R_Blaha  Offline OP
Milwaukee WI
I'm looking at taking off some weight on my project 69 Bee that I'm going to be dropping a hemi in. Has anybody installed these types of front ends with rack and pinion steering? I know with these you need to run coil overs, did you guys reinforce the shock towers? Thanks
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: School me on Tubular Front ends [Re: R_Blaha] #1078343
09/19/11 06:36 PM
09/19/11 06:36 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
I install the cap auto tubular k member and rack n pionon....if u go with the coil overs u will need to build a suitable shock support since now it bears all the weight, if u chose to run a torsion bar still a shock mount is not required...also rms unit is all in one unit not requiring an welding for a mount, but is a bit heaver,,,unit... give ray at cap a call248 200-8818 he can address any of your question..
Re: School me on Tubular Front ends [Re: pattyboy 572] #1078344
09/19/11 06:51 PM
09/19/11 06:51 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Rumor has it Ray has sold CAP.
Re: School me on Tubular Front ends [Re: moparguy7074] #1078345
09/19/11 07:15 PM
09/19/11 07:15 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Bobs pro fab
Re: School me on Tubular Front ends [Re: R_Blaha] #1078346
09/19/11 09:55 PM
09/19/11 09:55 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
If this is a race only car and the rules allow it why not bite the bullet and jump to a strut front end. Very simple and very light.
Re: School me on Tubular Front ends [Re: Blucuda413] #1078347
09/20/11 08:22 PM
09/20/11 08:22 PM
Mo.
racerx Offline
racerx  Offline
Mo.
So how much weight can one be saving by converting over to a strut front end over a torsion bar setup?
Re: School me on Tubular Front ends [Re: racerx] #1078348
09/20/11 08:44 PM
09/20/11 08:44 PM
Guitar Jones Offline
I didn't weigh the stuff I took out of my car but I would think it's got to be at least 150 pounds, maybe more.
Re: School me on Tubular Front ends [Re: Guitar Jones] #1078349
09/20/11 09:28 PM
09/20/11 09:28 PM
Mo.
racerx Offline
racerx  Offline
Mo.
wow
150 lbs
=10 th and a half
Re: School me on Tubular Front ends [Re: racerx] #1078350
09/20/11 09:36 PM
09/20/11 09:36 PM
wow
150 lbs
=10 th and a half
Well you can ax the K frame, how heavy is that thing? The lower control arms, and torsion bars have to be at least 50 to 75 pounds, stock brakes and spindles, the upper arms don't weigh much but if it's a P/S car there goes a bunch more. The Strange struts don't weigh much at all, neither does a Pinto rack and the CM control arms weigh next to nothing.
Re: School me on Tubular Front ends [Re: Guitar Jones] #1078351
09/20/11 11:17 PM
09/20/11 11:17 PM
Mo.
racerx Offline
racerx  Offline
Mo.
wow
150 lbs
=10 th and a half
Cool I'll be watching this post for further info on this as I'm also considering upgrading to a tubular front.....
Re: School me on Tubular Front ends [Re: racerx] #1078352
09/21/11 07:25 AM
09/21/11 07:25 AM
sweden
sshemi Offline
sshemi  Offline
sweden
isnt cap the one with a bad rep?
Re: School me on Tubular Front ends [Re: sshemi] #1078353
09/21/11 09:14 AM
09/21/11 09:14 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
You can ditch a large amount of weight by trimming the K like the SS/HA cars and going to coil overs.There nothing lighter than factory A arms.What it really needs and is seldom done is to change the upper A arm attachment points,. This corrects the geometry and keeps the wheels straight thruout their travel. In my opinion the factory had it right when they did the early pro stockers like mine. They used coil overs , a light tube replacing the K and added a Pinto rack. All else are factory parts just reposition. It still works fine 35 years later on my car at 158 mph .
home of the
Sox and Martin Hemi Duster
Re: School me on Tubular Front ends [Re: HEMIFRED] #1078354
09/21/11 09:28 AM
09/21/11 09:28 AM
ill
dennismopar73 Offline
ill
seen alot of issues comming from broken tubulars now that they getting out there more,
there is 0 wieght loss going to them,
i really think most are just going for the look rather than any actual gain,
Re: School me on Tubular Front ends [Re: dennismopar73] #1078355
09/21/11 09:35 AM
09/21/11 09:35 AM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
You can adjust more caster into a tubular upper A arm.
This post is available in double vision where drunk.
Re: School me on Tubular Front ends [Re: bwdst6] #1078356
09/21/11 09:45 AM
09/21/11 09:45 AM
ill
ill
mmm ok , dont know why ,, but ok ,,
never had that issue with any of my cars,
boy they sure look cool,
Re: School me on Tubular Front ends [Re: dennismopar73] #1078357
09/21/11 09:48 AM
09/21/11 09:48 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
at times old can still be better. I don't ike any aftermarket units with the lower A arms using two inside mounting points. overkill for a drag car.
home of the
Re: School me on Tubular Front ends [Re: HEMIFRED] #1078358
09/21/11 09:57 AM
09/21/11 09:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A strut front end is why better and ALOT lighter...
they all have 2 points weather its the single inner
pivot and a brake reaction rod or 2 inner pivots...
a Strange strut package(struts, hubs and brakes) is
right at $2000 and you still need a rack... speed cost
Re: School me on Tubular Front ends [Re: racerx] #1078359
09/21/11 09:58 AM
09/21/11 09:58 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
over 100lbs in my a body cuda.
Re: School me on Tubular Front ends [Re: bwdst6] #1078360
09/21/11 09:59 AM
09/21/11 09:59 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
There is not 150lbs to loose up front. Total wieght of all stock parts isw 123lbs. Here is the list,idler arm 2lbs stock kframe 37lbs. upper arms with b joint5lbs ea. lowerc arms 9 lbs ea. strut arms 1 lb ea. lower ball joint 3 lbs ea. tie rods 1 lb ea. t bars 7lbs ea. spindle 5 lbs ea. manual gear box 13 lbs. pitman arm 2 lbs. center link 5 lbs. total 123 lbs. The only savings when changing over is k frame is lighter upper are heavier lowers are the same a wash from t bars to coil overs. you do gain some header clearence and are able to adjust caster more. When putting in rack and pinion bumpstear is a pain to work out. Jake
JAKES AUTOMOTIVE
Re: School me on Tubular Front ends [Re: sshemi] #1078361
09/21/11 10:00 AM
09/21/11 10:00 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yes it is,some say good...but i saw it myself i have cap on my 74 dart...and another friend had to send his whole set up back to em for a new one after tons of $$$$ tryin to get it right.
