Re: School me on Tubular Front ends
[Re: R_Blaha]
#1078343
09/19/11 06:36 PM
09/19/11 06:36 PM
Posts: 452 new york usa
pattyboy 572
new york usa
I install the cap auto tubular k member and rack n pionon....if u go with the coil overs u will need to build a suitable shock support since now it bears all the weight, if u chose to run a torsion bar still a shock mount is not required...also rms unit is all in one unit not requiring an welding for a mount, but is a bit heaver,,,unit... give ray at cap a call248 200-8818 he can address any of your question..
[Re: pattyboy 572]
#1078344
09/19/11 06:51 PM
09/19/11 06:51 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Rumor has it Ray has sold CAP.
[Re: Blucuda413]
#1078347
09/20/11 08:22 PM
09/20/11 08:22 PM
Posts: 4,078 Mo.
racerx
Mo.
If this is a race only car and the rules allow it why not bite the bullet and jump to a strut front end. Very simple and very light.
So how much weight can one be saving by converting over to a strut front end over a torsion bar setup?
[Re: racerx]
#1078348
09/20/11 08:44 PM
09/20/11 08:44 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
I didn't weigh the stuff I took out of my car but I would think it's got to be at least 150 pounds, maybe more.
[Re: Guitar Jones]
#1078349
09/20/11 09:28 PM
09/20/11 09:28 PM
Posts: 4,078 Mo.
racerx
Mo.
wow 150 lbs =10 th and a half
[Re: racerx]
#1078350
09/20/11 09:36 PM
09/20/11 09:36 PM
Guitar Jones
Well you can ax the K frame, how heavy is that thing? The lower control arms, and torsion bars have to be at least 50 to 75 pounds, stock brakes and spindles, the upper arms don't weigh much but if it's a P/S car there goes a bunch more. The Strange struts don't weigh much at all, neither does a Pinto rack and the CM control arms weigh next to nothing.
[Re: Guitar Jones]
#1078351
09/20/11 11:17 PM
09/20/11 11:17 PM
Posts: 4,078 Mo.
racerx
Mo.
Cool I'll be watching this post for further info on this as I'm also considering upgrading to a tubular front.....
[Re: sshemi]
#1078353
09/21/11 09:14 AM
09/21/11 09:14 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
You can ditch a large amount of weight by trimming the K like the SS/HA cars and going to coil overs.There nothing lighter than factory A arms.What it really needs and is seldom done is to change the upper A arm attachment points,. This corrects the geometry and keeps the wheels straight thruout their travel. In my opinion the factory had it right when they did the early pro stockers like mine. They used coil overs , a light tube replacing the K and added a Pinto rack. All else are factory parts just reposition. It still works fine 35 years later on my car at 158 mph .
home of the Sox and Martin Hemi Duster
[Re: bwdst6]
#1078356
09/21/11 09:45 AM
09/21/11 09:45 AM
Posts: 2,177 ill
dennismopar73
ill
mmm ok , dont know why ,, but ok ,, never had that issue with any of my cars, boy they sure look cool,
[Re: HEMIFRED]
#1078358
09/21/11 09:57 AM
09/21/11 09:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
seen alot of issues comming from broken tubulars now that they getting out there more, there is 0 wieght loss going to them, i really think most are just going for the look rather than any actual gain,
at times old can still be better. I don't ike any aftermarket units with the lower A arms using two inside mounting points. overkill for a drag car.
A strut front end is why better and ALOT lighter... they all have 2 points weather its the single inner pivot and a brake reaction rod or 2 inner pivots... a Strange strut package(struts, hubs and brakes) is right at $2000 and you still need a rack... speed cost
[Re: racerx]
#1078359
09/21/11 09:58 AM
09/21/11 09:58 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
over 100lbs in my a body cuda.
[Re: bwdst6]
#1078360
09/21/11 09:59 AM
09/21/11 09:59 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
There is not 150lbs to loose up front. Total wieght of all stock parts isw 123lbs. Here is the list,idler arm 2lbs stock kframe 37lbs. upper arms with b joint5lbs ea. lowerc arms 9 lbs ea. strut arms 1 lb ea. lower ball joint 3 lbs ea. tie rods 1 lb ea. t bars 7lbs ea. spindle 5 lbs ea. manual gear box 13 lbs. pitman arm 2 lbs. center link 5 lbs. total 123 lbs. The only savings when changing over is k frame is lighter upper are heavier lowers are the same a wash from t bars to coil overs. you do gain some header clearence and are able to adjust caster more. When putting in rack and pinion bumpstear is a pain to work out. Jake
JAKES AUTOMOTIVE
[Re: sshemi]
#1078361
09/21/11 10:00 AM
09/21/11 10:00 AM
fishy340
LONG ISLAND
isnt cap the one with a bad rep?
yes it is,some say good...but i saw it myself i have cap on my 74 dart...and another friend had to send his whole set up back to em for a new one after tons of $$$$ tryin to get it right.
