Another ballast question #1078257
09/19/11 03:24 PM
09/19/11 03:24 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Should resistor be hot when the car is running.I am having a overcharging promblem and resistor is hot almost right away when I start car.
Re: Another ballast question [Re: Crabra] #1078258
09/19/11 04:05 PM
09/19/11 04:05 PM
they definitely get hot enough to burn you but I am not sure how that takes but I'm sure it is not very long. More details, what charging voltage (at alt, at battery), when did it start, any parts changes that precipitated it, reg grounded good
