Re: What is the correct style master cylinder....
[Re: HelleOnWheels]
#1077799
09/19/11 02:44 AM
09/19/11 02:44 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
As far as I can tell, you can use a Dorman M71258. Summit racing has them p/n DHB-M71258 for $29.95. This one is a bolt down type.
Cheers,
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
[Re: HelleOnWheels]
#1077800
09/19/11 09:42 AM
09/19/11 09:42 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
1967 Dodge R/T 440 - 4 wheel drum brakes I currently have a spring(tension)loaded lid on my master cylinder. I need to replace it and am only finding bolt down style lids.
My 67 Dodge parts manual shows a picture of a spring style lid, but my 67 Dodge service manual shows a bolt down style lid.
Which is correct? Did they use both during 67?
Where should I buy my master cylinder?
The bolt down lid is the correct one for a 1967 with DRUM brakes , the picture you see in the parts manual is probably a DISC master cylinder.
[Re: HelleOnWheels]
#1077801
09/22/11 12:34 PM
09/22/11 12:34 PM
Posts: 3,491 Cold Spring, NY
1970GTX
Cold Spring, NY
All 67 - 70 B body front drum brake cars used this one.
Cardone Brake Master Cylinder Part No. 10-1323
Many have had the holes rethreaded to the next bigger size, so you might need adapters to continue to use stock fittings on the lines.
[Re: 1970GTX]
#1077802
09/27/11 09:45 PM
09/27/11 09:45 PM
Posts: 228 FL
HelleOnWheels
FL
This appears to be for a POWER drum brakes setup. I didn't say in my original post, but I have manual drum brakes front and rear on the car.
[Re: JohnRR]
#1077805
09/27/11 11:04 PM
09/27/11 11:04 PM
Posts: 8,342 Crook County, ILL
Mastershake340
Crook County, ILL
see the boot hanging out the back in that picture , that is a manual setup but I am pretty sure the master is the same for power vs. non power .
It is, only difference is the power unit has a teardrop shaped piston retainer held on by a screw on the flange, whereas the manual brake version has a boot assembly bolted on with 2 bolts. The master cylinder itself is the same, just need the boot or piston retainer mounted on the flange for your application.
