Re: Car starts when key is RELEASED, why?
[Re: roe]
#1077415
09/19/11 08:12 PM
09/19/11 08:12 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
when my RC did that, it ended up being a bad fusible link. i bypassed it with a switch under the dash.
[Re: JohnRR]
#1077417
09/19/11 08:44 PM
09/19/11 08:44 PM
Posts: 3,683 The Historic Hudson Valley
MONC
More info ... what year is the car , electronic or points ?? before I can make an ASSumption of the problem .
70 E body - electronic ignition.
Does it have a 2 prong Ballast or a 4 prong ?
2
[Re: RodStRace]
#1077418
09/19/11 08:48 PM
09/19/11 08:48 PM
MONC
Go to yer wirin' diagrams, ya swabbies! Ya cen see that therrrs a diff circuit be supplying the coil in run 'n start. Iffn you ain't got spark in start, that circuit be caddywumpus...
So Rod, you with Pacnorthcuda that it's the circuit to the coil? I don't speak Pirate-ese.
Do you agree with my test to check when cranking at the coil?
[Re: MONC]
#1077419
09/19/11 10:07 PM
09/19/11 10:07 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
I would start earlier in the circuit. Hook up a test light to the drivers side of the ballast resister, position it so you can see it through the windshield. Crank. Light? if Yes, check the other terminal on the same side (I am assuming at this point you have a 4 prong resister), crank Light? No? Thats a Problem!!! Then do the same thing on the interior side of the bulkhead connector (trace the dead wire--its green I think) does it light? Yes? clean/repair the bulkhead male/female spade connections. No? damn!!! Might me an ignition switch problem.
[Re: MONC]
#1077421
09/20/11 05:46 AM
09/20/11 05:46 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
Yes, if there is no voltage at the coil during cranking it will not start. New engine harness ?
[Re: 451Mopar]
#1077427
09/22/11 08:00 AM
09/22/11 08:00 AM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
Had a simular problem last year on my 5th Avenue w/318. May sound strange, but it turned out to be the distributor. The bushings where loose, causing the air gap to be almost closed at times, open enough to start others. I run an HEI, so no ballast or ECU. Worth a try.
Eric
Re: Car starts when key is RELEASED, why? *UPDATE*
[Re: RapidRobert]
#1077431
09/24/11 06:21 PM
09/24/11 06:21 PM
Posts: 183 Eden, Texas
Strawdawg
Eden, Texas
so what voltage do you see at the coil when you are actually cranking it over?
Sounds like you either have a large voltage drop, or the battery is basically discharged.
Steve
[Re: Strawdawg]
#1077432
09/24/11 06:52 PM
09/24/11 06:52 PM
MONC
8.5 volts at coil when cranking.
[Re: RapidRobert]
#1077433
09/24/11 06:54 PM
09/24/11 06:54 PM
MONC
Thoughts?
it "runs" so the pickup/coil/ecu (hard components) are good and the ECU is grounded. Check the wiring schematics how it's wired as only the coil positive primary terminal and the "point" of the ECU pentastar connector (4 pin) need fire in start (ign2) as the pickup triggers the ECU which opens the coil pri makeing the secondary fire. Either one of those hard components is not getting fire in "start" or in "start" it is mis wired and something is getting grounded that should not be grounding.
I replaced the ECU and the coil , and checked I was getting a good ground at the ECU when I changed it.
But I understand what you are saying, something is not getting fire in the start. I don't think it's miswired because it was working fine before.
