Re: fluid damper inst help [Re: Thumperdart] #1076813
09/18/11 02:01 PM
09/18/11 02:01 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Did you check the clearances? Alot of dampers, if not most, need honed to fit.
Bingo...........mike the crank snout and the id of the dampner and go from there. Mine was about a .002 press fit iirc.
.002 is awful tight. I would go .0015 to .001 press fit.
Re: fluid damper inst help [Re: Hot 340] #1076814
09/18/11 03:24 PM
09/18/11 03:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Again, that was off the top of my head so who knows.
Re: fluid damper inst help [Re: dOc …] #1076815
09/18/11 10:16 PM
09/18/11 10:16 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Mine won't fit cold. I heat it up 250 degrees or a little more and it slides right on. I also use a little anti-seize.
And how much "grunt" on the puller do you have to use ...to pull it off?
Not much. The best way to describe it is a light press fit.
Yeah, it's got a smallblock.
