Has anyone had any issues with starter fitment using a quicktime bellhousing on a smallblock?I'm in the mockup/fitment stage and it seems as if the starter pinion gear is actually just contacting the ring gear(no clearance in static state)I'm using a mcleod flywheel.It is almost as if I would need to add a shim of some sort to space the starter away from the flywheel towards the front of the engine.Any insight would be appreciated.I'm wondering if not being able to use the original dust shield(which i believe acts as a shim)has something to do with this. thanx
P.S. I'm using a chrysler mini starter
