70 Dart Exhaust Question #1075828
09/15/11 10:10 PM
09/15/11 10:10 PM
Texas
jetdoctor_75402 Offline OP
super gas
super gas
Texas
Looking to install dual exhaust on /6 to 5.2 conversion, car is 4 speed with power steering. I have a set of rear exit exhaust manifolds that came off of a magnum engine (truck setup I believe) and 2 sets of pass car exhaust manifolds. Of course the biggie is the clearance issues with the steering linkage and clutch at this point. Would appreciate some ideas on what works with a minimum of problems. Thanks
Doc
Re: 70 Dart Exhaust Question [Re: jetdoctor_75402] #1075829
09/15/11 10:17 PM
09/15/11 10:17 PM
the early ('92/some 93?) magnum ex manifolds have ~2&1/8 maybe 2&1/4" outlets whereas the later mag manifolds have ~1&7/8" outlets, quite a difference. Yes it's whether the DR one will fit
Re: 70 Dart Exhaust Question [Re: RapidRobert] #1075830
09/16/11 12:24 AM
09/16/11 12:24 AM
Texas
super gas
super gas
Texas
oh boy, mockup time, using a late 340 cross member to mount everything. so far so good, guess we will mount ex manifolds and see if they drop in the engine bay.
thanks for info, I need to measure the holes to determine which set we have. think they are 93.
doc
