392 Hemi Old Style
#1075219
09/14/11 08:43 PM
09/14/11 08:43 PM
Posts: 108 Wisconsin
MagnumExpress
Wisconsin
I am building a motor for a freind and am wondering if anyone knows how much these motors can be over bored. it is at .030 over now.
#9 in the world. 2006 IHRA Super Rod 2010 IHRA Div.5 Hot Rod Champion
Re: 392 Hemi Old Style
[Re: MagnumExpress]
#1075221
09/14/11 11:20 PM
09/14/11 11:20 PM
Posts: 43,206 Bend,OR USA
Cab_Burge
I have seen 392 blocks crack cylinders when bored .090 over Don't bore it any more than you absolutely have to, the orignal blocks where designed to be small bores(3.750 was stock on the 331 if I'm remembering correctly) once Mopar changed the bore size to 4.00 they had to make and design another motor( B&RB) for production use I have ran a lot of the early Chrysler Hemi motors I like them a lot but they do have thier limits If your friend is looking to go all out on a early style 392 motor have him look at the Donovan blocks and Hot Heads aluminum cylinder heads BTW, back in the day .060 was consider the max you wanted to bore a 392 block, regardless of which block, standard, RR or A-1 block
