Engine Run In Stand Design- Who's is best and Why? #1074880
09/13/11 11:46 PM
09/13/11 11:46 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I posted over in general but figured the racer crowd might be more in touch with the subject.............
I was checking out the features of the "Easy-Run" design and like it, the placement of the controls, battery, radiator, etc. is very nicely laid out. However there's no way I'm dishing out over 2K to buy one when I can build my own with some simple box tubing and a few ready made store bought componants so I'm going to build my own.
I can tough it out and start from scratch but if anyone has design plans/dimensions, etc. for a similar design as the Easy-Run I'd love to have a head start!
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074881
09/14/11 12:00 AM
09/14/11 12:00 AM
New York
polyspheric Offline
polyspheric  Offline
New York
You can only break in the cam and check for leaks.
The rings need cylinder pressure to seat - and that means a load.
If you blip the gas, it's upside down instantly.
Boffin Emeritus
Re: Engine Run In Stand Design- Who's is best and Why? [Re: polyspheric] #1074882
09/14/11 12:15 AM
09/14/11 12:15 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I won't be using it to actually break in an engine, I need a new one for running my mule engine on that I test run restored carburetors with. My current one is an old cobbled together rig that I'm not happy with.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074883
09/14/11 02:20 AM
09/14/11 02:20 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Is there any device or way to add a Load on a test stand like this?
I know Dyno's use Water Brakes and Eddie Current brakes. I believe that is also a BIG part of their expense as well. Next to the Software.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: DakFink] #1074884
09/14/11 02:25 AM
09/14/11 02:25 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not the best option but I have a core 727 that I plan to use & I'll lock it up like a transbrake so I can load the engine against the torque convertor to help seat the rings.... I'll probably smoke the trans by the time I'm done but it's just a spare core anyway....
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074885
09/14/11 03:21 AM
09/14/11 03:21 AM
Utah
topbrent Offline
topbrent  Offline
Utah
That Easy-Run is very thoughtfully designed piece. The creator of that stand was at MATS a few years back. In person, it was easy to see why he designed and built that stand the way he did.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: 1_WILD_RT] #1074886
09/14/11 06:36 AM
09/14/11 06:36 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Thats what I did and Scott other then time you can build one pretty cheap and not alot of time in it, I also have a semi junk trans to put a load on things.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074887
09/14/11 07:37 AM
09/14/11 07:37 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
My home built. Started with an overseas shipping rack for coiled aluminum foil stock.
If you like drag racing, support your local track.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: CHAPPER] #1074888
09/14/11 07:38 AM
09/14/11 07:38 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
2
Re: Engine Run In Stand Design- Who's is best and Why? [Re: CHAPPER] #1074889
09/14/11 07:39 AM
09/14/11 07:39 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
3
Re: Engine Run In Stand Design- Who's is best and Why? [Re: CHAPPER] #1074890
09/14/11 07:40 AM
09/14/11 07:40 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Re: Engine Run In Stand Design- Who's is best and Why? [Re: CHAPPER] #1074891
09/14/11 07:42 AM
09/14/11 07:42 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
..I have had NO problem with it wanting to move around or upset when throttle is wacked..
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074892
09/14/11 08:05 AM
09/14/11 08:05 AM
Lehigh Acres, Florida
rickstershemi Offline
Scott I built the one in this video for under $100 in steel, casters and half a day on a Saturday cutting and welding it up.....it's very stable and doesn't walk around at all.....plus it's very easy to roll with the casters.....something like this should get you where you want to be cheap....no reason to spend big bucks on a commercially made unit IMO
Rickster
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074893
09/14/11 08:50 AM
09/14/11 08:50 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Around here there are tractor dynoes, and they are a water type load device that hooks to the pto. It could be easy enough to adapt the PTO to a flange or a yoke to hook to the tranny, wouldnt think it would take much at all. Im sure if your around an implament shop they would let you use the dyno. We were able to use the one from a local shop, and tried this on an irrigation engine I rebuilt.
Kasey
Re: Engine Run In Stand Design- Who's is best and Why? [Re: ScottSmith_Harms] #1074894
09/14/11 09:50 AM
09/14/11 09:50 AM
WI.
Scotts71chall Offline
WI.
My good friend built this.
It does not flip over when ya hit the gas!
Re: Engine Run In Stand Design- Who's is best and Why? [Re: Scotts71chall] #1074895
09/14/11 10:45 AM
09/14/11 10:45 AM
an8sec70cuda Offline
My dad and I built one very similar to Scotts71chall, only it doesn't look nearly as nice, lol. It works great though and doesn't even come close to flipping over when you romp on the throttle. Last motor I had on it was my Indy headed 440 that makes close to 700 hp.
I just use an old cast iron 4 speed bellhousing and flywheel.
It was worth every bit of time and effort we put into it. Built w/ scrap we had laying around. Retorquing heads, swapping valvesprings after cam break-in, fixing leaks, and any other problems that come up...much easier to fix on the stand rather than in the car.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: Engine Run In Stand Design- Who's is best and Why? [Re: an8sec70cuda] #1074896
09/14/11 09:39 PM
09/14/11 09:39 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Heres the one I built last winter when I needed to run a couple of motors. Bought only $25.00 worth of iron to go with what I had laying around. Ignition, fuel, and rad were left overs. Have more in gauges and switches, but hey, it had to look nice. Casters are off of the toolbox in my trailer. It does not scitter around floor, gauges dont vibrate, and it DEFINATLEY doesnt flip over when you blip the throttle. Had a stout blown SBC on it and it didnt flip it. PM me if you want some dimensions or tips. Depending on what you have laying around and going a little less expensive route on gauges and switches, a person should be able to build a nice one for way under $500. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
1980 Plymouth Arrow 572 Hemi.
242" Mullis Dragster. 6.90@ 200mph
Re: Engine Run In Stand Design- Who's is best and Why? [Re: BANDIT] #1074897
09/14/11 10:57 PM
09/14/11 10:57 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Heres the one I built last winter when I needed to run a couple of motors. Bought only $25.00 worth of iron to go with what I had laying around. Ignition, fuel, and rad were left overs. Have more in gauges and switches, but hey, it had to look nice. Casters are off of the toolbox in my trailer. It does not scitter around floor, gauges dont vibrate, and it DEFINATLEY doesnt flip over when you blip the throttle. Had a stout blown SBC on it and it didnt flip it. PM me if you want some dimensions or tips. Depending on what you have laying around and going a little less expensive route on gauges and switches, a person should be able to build a nice one for way under $500. Jim [/quote
That looks great! Next time you take a picture though be sure to tuck the rest of the dog back up into the control panel .
68 Barracuda Formula S 340
Re: Engine Run In Stand Design- Who's is best and Why? [Re: Bad340fish] #1074898
09/15/11 01:20 AM
09/15/11 01:20 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Here he is shooting out of one of the headers, he came out in really good shape.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: Moparnut426] #1074899
09/15/11 06:54 AM
09/15/11 06:54 AM
DakFink Offline
DakFink  Offline
Kasey
Hmmm? Maybe a Boat Prop in a barrel of water connected to a shaft that bolts to the fly wheel or some kind of U-joint??? Just some ideas.
Re: Engine Run In Stand Design- Who's is best and Why? [Re: DakFink] #1074900
09/15/11 07:13 AM
09/15/11 07:13 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Kasey
I think that would lead to a nice wet shop
Re: Engine Run In Stand Design- Who's is best and Why? [Re: BANDIT] #1074901
09/27/11 08:37 PM
09/27/11 08:37 PM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
Bandit
I need to build one , I really like yours. PM sent for build info
Donnie
Re: Engine Run In Stand Design- Who's is best and Why? [Re: BANDIT] #1074902
09/27/11 08:50 PM
09/27/11 08:50 PM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
You using a scatter shield and flywheel? or a convertor some how??
Re: Engine Run In Stand Design- Who's is best and Why? [Re: Blown61] #1074903
09/27/11 08:54 PM
09/27/11 08:54 PM
Middletown , Ohio
Middletown , Ohio
Currently have a couple 727's I could use , I'm also open to getting a flywheel and bellhousing...
Oh sorry...... Thought you was asking me ,
