I typically shoot the top tank, bottom tank and Water Pump housing.
Look for the delta T across the radiator top to bottom. The more temperature differential across the radiator top to bottom (within reason) the better. I sometimes pull the radiator cap while it is running and shoot the actual liquid, but it is usually the same as the top tank.
This generally eliminates the inaccuracys of the gauge and you only have to deal with what ever the accuracy of the Laser Thermometer is. Mine is a Cen-Tec unit that works pretty well for the price, but I am sure there are others.
