Re: Change axles need new drums why?
[Re: flatiron]
#1074521
09/13/11 09:18 PM
09/13/11 09:18 PM
Posts: 724 PA USA
flatiron
PA USA
[Re: flatiron]
#1074523
09/13/11 10:06 PM
09/13/11 10:06 PM
Posts: 5,894 Florida
Locomotion
I'm going to a spool with the BBP axles that DR Dif sells on here. I currently have a sbp 8.75 I was told I was gonna need to get a set of b body drums and backing plates. I'm just wondering why?
SBP A-body brakes have a different "offset". The wheel bearing is machined at a different location, the brakes are smaller and the drum register is smaller, all specific to the 4" bolt pattern.
You could have gotten the new axles machined for your existing brake set-up using a 4.5" bolt pattern, but you'd have to redrill brake drums every time you changed them, IF you could find them and related parts at a reasonable price.
10" B, E, BBP '73 & up A body and F-body are basically the same. M & J body too, I believe. All much easier and cheaper to find replacement/service parts for.
[Re: Locomotion]
#1074524
09/13/11 10:37 PM
09/13/11 10:37 PM
Posts: 15,487 Florida
scratchnfotraction
stock A-body brakes are 1 3/4 wide and do not mix with any other brakes.
with the large brake offset you need the large brake backing plates and drums
my moser axles with large brake offset and green bearings 5 on 4.5 wbp made my whole A-body 8 3/4 a 1/2" wider(1/4" each side) in my 68 dart.
i used brakes from a 73 c-body for 11 x 2.5 drums and shoes.
it also used a 7" rim with 4.5 backset to keep the tire rim in the center of wheel well with a 245/60/15 in the fenders of the 68 Dart,lips un-touched.
[Re: Locomotion]
#1074525
09/13/11 10:40 PM
09/13/11 10:40 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
what spline count and spool are you wanting to get? I know you can get 30 spline axles in the SBP and still use your exhisting.. I dont know about 35 spline sbpS...
I am truckless..
