Can some ID this piston please?
#1074437
09/13/11 04:16 PM
09/13/11 04:16 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Told it was for a 440.. I see its .040 over, it is an aluminum piston. Says SQ on the top, inside says U.S.A 1650 and 350P I want to know what compression etc.
Thanks!
RS23L7 4-Speed
Re: Can some ID this piston please?
[Re: 1_WILD_RT]
#1074439
09/13/11 05:22 PM
09/13/11 05:22 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
It's a flat top, measure the compression height & it'll be pretty easy to figure it out.....
, more than likely a low compression ash tray , you have a set of 8 to give out as Xmas gifts to your motorhead friends ...
[Re: 1_WILD_RT]
#1074442
09/13/11 06:37 PM
09/13/11 06:37 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
1.991" is the CH of the original '67 or '70-'71 HP piston, with 90 cc chambers and a .020" gasket it would have a true CR of about 8.8-1
[Re: John_Kunkel]
#1074443
09/13/11 07:58 PM
09/13/11 07:58 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Looks like a sealed power or a Federal Mogul.. Speed Pro is the same company...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 1_WILD_RT]
#1074444
09/13/11 09:24 PM
09/13/11 09:24 PM
Mopar_Mike
Danville, NH
Thanks all. I agree this is the optional higher CR piston. I ended up finding the same link as you 1_Wild_RT.. Thanks.
RS23L7 4-Speed
[Re: Mopar_Mike]
#1074445
09/14/11 09:50 AM
09/14/11 09:50 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Looks like the speedpro/federal mogul/etc L2266 piston. It doesn't give anywhere near the advertised compression ratio. My first 440 had a set of them in it. I swapped them out for some ROSS flattops...big difference.
[Re: Mopar_Mike]
#1074448
09/14/11 11:36 AM
09/14/11 11:36 AM
an8sec70cuda
I may be wrong, but I believe the only FM/Speed Pro/Sealed Power forged piston that gives a decent compression ratio is the L2355 "six pack" piston. It has 4 valve reliefs.
[Re: 1_WILD_RT]
#1074451
09/14/11 04:46 PM
09/14/11 04:46 PM
John_Kunkel
Rio Linda, CA
The 1.991" piston in question was first used in the '67 440 with closed chamber heads and it was advertised as being 10.1
The piston was resurrected for use in the lower compression '70-'71 440 with open chambers and was advertised at 9.7 unlike the "low compression pig" that followed in '72.
In those years the standard 440 and the HP 440-4 used the same piston.
