Re: What type of holley carb is this
[Re: bigsbigelow]
#1074297
09/13/11 06:47 PM
09/13/11 06:47 PM
Posts: 33 Sweden
Petri.
Sweden
Thanks guys,i bought 2 holleys today because the price was so good.
3310-4 4160 750cfm vacum secondaries List-6210 4165 650cfm manual secondaries,spread bore
So now i need some more help again,i have problems getting my charger 68 383 working good when cruising at idle for long times,it gets too much fuel at idle so i have to have the idle at about 1000rpm,it works great at wot but i cruise it alot more than drive it with wot, i also want to have down the gas mileage a little because it is terrible today with my 1412 800cfm edelbrock,but also i dont want to loose yo much power,here is my engine setup.
Block 383 Hi-Nickel Content (not original block) Bore .030 over Mopar steel rods Keith Black 9.0 to 1 comp pistons Moly rings Clevite 77 main & rod bearings Forged steel crank shaft Complete balanced assembly Cylinder heads (906) large valves with hard seats Valve job with comp springs Comp hyd cam 272 degree x 480" of lift Cloyes dbl roller chain & gears Melling high volume oil pump Intake manifold is a HP 383 with Edelbrock 800 cfm mod #1412 Pertronics electronic ignition with MSD coil Exhaust is a 383-440 magnum HP manifolds
I dont know much about carbs but im trying to learn,wich carb of these three i now have would work for me best, is it possible to get it working with the 1412 that is on it now,the carb is like new,can it be problems with float level in it or would it work better with smaller jettings,i think it is taken right out of the box,i dont know because i bought i from the states,we have onlu set the ignition and screwed at the idle mixture screws but it did not get any better.
/Petri
