727 dipstick ? #1074244
09/13/11 01:16 AM
09/13/11 01:16 AM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
Is the tube for a dipstick to the trans supposed to have a gasket or o-ring? I've had this annoying leak from it and despite unbolting it and reinserting it, I still leak out a fair amount of fluid. Getting a little frustrated
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: 727 dipstick ? [Re: Prince_Valiant] #1074245
09/13/11 01:33 AM
09/13/11 01:33 AM
Santa Fe,Texas
TexasMopar Offline
TexasMopar  Offline
Santa Fe,Texas
Yes the tube has a "O" ring on it. Most likely why you have the leakage.
Re: 727 dipstick ? [Re: TexasMopar] #1074246
09/13/11 10:48 AM
09/13/11 10:48 AM
If the O ring is good may have 2 drop the pan clean the hole/tube end w brake kleen & silicone it. I had a pesky one finally got tired of repeated leaking so I bit the bullet & dropped the pan. Gave me an opportunity to ch the gasket/filter/adj bands. Good visual on the O ring & go from there
Re: 727 dipstick ? [Re: RapidRobert] #1074247
09/13/11 11:04 AM
09/13/11 11:04 AM
scratchnfotraction Offline
I recomend droping the pan,clean with brake clean,airdry,new o-ring and use the MOPAR Black ATF/RTV from the dealer.
well worth the 5$ for the ATF/RTV and new o-ring from the dealer.
also a good time to up the pan gasket for the reusable one from the dealer 727-#2464324ac
Re: 727 dipstick ? [Re: scratchnfotraction] #1074248
09/13/11 11:33 AM
09/13/11 11:33 AM
Milwaukee, WI
Milwaukee, WI
thanks guys...I will follow your advice scrathin'...
Re: 727 dipstick ? [Re: Prince_Valiant] #1074249
09/17/11 01:57 PM
09/17/11 01:57 PM
5thAve Offline
5thAve  Offline
That's some nice dealer advertising
O ring it and throw some silicone on it. Any kind will do. If it leaks after that the tube could have a crack in it.
Re: 727 dipstick ? [Re: 5thAve] #1074250
09/17/11 04:07 PM
09/17/11 04:07 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Is there supposed to be any kind of seal at the top of the tube, or should it be able to vent?
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: 727 dipstick ? [Re: closer9] #1074251
09/17/11 05:31 PM
09/17/11 05:31 PM
the dip tube should have a rubber stopper under the tube cap with a small metal washer under the rubber plug.
the flat stick is pinched/staked to lock the washer under the rubber plug.
when in place on the stick,it seals the dip tube and the tranz vents thru the vent in the front pump,at the top behind the TC.( this is were most 4x4 fill up with water when deep water crossing)
Re: 727 dipstick ? [Re: scratchnfotraction] #1074252
09/18/11 02:43 PM
09/18/11 02:43 PM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
Do yourself a big favor. Get the MOPAR ATV. It cost less than a tube of silicone. Unless you can get everything spotless, its 50/50 if the silicone will seal. The MOPAR ATV even sealed a leak from the outside. I had one of those plastic plugs they use for the cheap fluid change seeping fluid. Glopped some of the ATV all over it - bone dry for months now.
