Is it possible... bolt a 727 to a GM or Ford block? #1073959
09/12/11 08:45 PM
09/12/11 08:45 PM
Canada/USA
ragingram Offline OP
Canada/USA
Just wondering if this is possible.
To take a Chrysler 727 and Bolt it to a Ford or GM block... I know you can do a T400 and got to a chysler pattern but can you go the other way??
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: ragingram] #1073960
09/12/11 08:49 PM
09/12/11 08:49 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Why would you want to?
The reason that I ask is a powerglide is cheaper & lighter
the turbo 400 is stronger
the c-6 is better than a 727.
under what app. do you mean.racing or street driving.makes a difference.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: grncpe] #1073961
09/12/11 10:52 PM
09/12/11 10:52 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
A-1 proflite about $7000 nowadays 904/727 hybrid custom everything I have seen them behind chevy pontiac ford etc
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: grncpe] #1073962
09/12/11 11:14 PM
09/12/11 11:14 PM
Utah, USA
1964superstock Offline
Utah, USA
GM LS conversion into a mopar with stock 727 so everything fits.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: grncpe] #1073963
09/12/11 11:18 PM
09/12/11 11:18 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
Maybe he wants the fastest auto trans available for N/A....
The 904 style Proflite.
You know.....like all the fast Fords and GM cars have.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: jim sciortino] #1073964
09/13/11 12:13 AM
09/13/11 12:13 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
There was a factory GM motor that had a Chrysler auto trans bolted to it from the factory - 80's era mail carrier Jeeps had Pontiac iron duke 4 cylinder motors with 904 transmissions. That fact let GM cars run 904's in the Stocker classes...
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: ragingram] #1073965
09/13/11 12:44 AM
09/13/11 12:44 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
It is far from just a bolt-on. But like it was already said thats the ticket for a low drag comp trans, they use an adapter on a AMC 727 or 904. The adapter is also rated as the flywheel sheild. Nice stuff/big money.
"Just a Bracket car dressed up like a streetcar"
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: ragingram] #1073966
09/13/11 08:10 AM
09/13/11 08:10 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Advance Adaptor GM to AMC torqueflite:
http://www.advanceadapters.com/products/pn-716131-a/
Check with Wilcap, as they might make an adapter that would work.
Perhaps JW has an UltraBell bellhousing adaptor for the 727.
Or, ... just use a GM trans and save the hassle.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: topbrent] #1073967
09/13/11 08:45 AM
09/13/11 08:45 AM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
some mail jeeps had 904's with chevy bells
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: ragingram] #1073968
09/13/11 10:50 AM
09/13/11 10:50 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I'm pretty sure SMR racing transmissions sells them he was telling me about them and that many do convert anyways a few years back.
http://smrtrans.tripod.com/smrtransmissionsintro/index.html
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: jim sciortino] #1073969
09/13/11 11:20 AM
09/13/11 11:20 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
My guess is that if he was looking at using a ProFlite he wouldn't have asked this question.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: BobR] #1073970
09/13/11 02:25 PM
09/13/11 02:25 PM
Trumbull,CT.
Trumbull,CT.
You make a good point.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: jim sciortino] #1073971
09/13/11 08:43 PM
09/13/11 08:43 PM
Guitar Jones Offline
Well maybe he's looking to make a poor mans ProFlite.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: Guitar Jones] #1073972
09/14/11 12:10 PM
09/14/11 12:10 PM
Canada/USA
Canada/USA
Hard to tell what I want to do... Lets say you have one hell of an engine with a GM BB bolt pattern on the block and you have one hell of an 727. You either have to throw one out or mate the two!!! I want to mate the two
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: grncpe] #1073973
09/14/11 04:52 PM
09/14/11 04:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's a rather unique opinion.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: John_Kunkel] #1073974
09/14/11 06:25 PM
09/14/11 06:25 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
I guess you never had a 727 blow up on you yet...
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: ragingram] #1073975
09/14/11 07:58 PM
09/14/11 07:58 PM
Utah
topbrent Offline
topbrent  Offline
Utah
I am not big on hell. I avoid it where possible.
Life would probably be less hellish if you used a basic (or perhaps even "one hell off a...") stout TH400 or powerglide on that "GM BB Bolt pattern block."
Saves you the hell of adaptors and the inevitable fitment issues.
No need for ask for more hell in ones life.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: grncpe] #1073976
09/14/11 09:44 PM
09/14/11 09:44 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
No big differences between a C6 and a 727. Both used the Simpson planetary design as did the GM Turbo Hydramatics. It was common in the 70's for Ford racers to put a 727 gearset in their C6 case. NHRA put a stop to this by checking for park in the transmissions because the parking lever wouldn't work in a C6 with the 727 gears.
I've seen Fords and GM scatter transmissions like a 727 in the past.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: sixpakdodge] #1073977
09/14/11 10:40 PM
09/14/11 10:40 PM
I've built 904/998/999's, 727's, C6's FMX's, C4's, TH 400's, TH 350's, PG's, 700R4, 4L60E's, 42RH's, 44/46/47RH's and 42/46/47/48RE's. As well as countless front wheel drive transaxles. They all go bad. The TorqueFlites don't have any more inherent problems than any other transmission. C6's are a poor copy of a 727 as is the C4 a poor copy of the 904. They put the servos in the side of the case so when they are applied they tend to spread the case.
But back to the OP, just put a GM trans behind your GM engine, BB and SB are the same pattern, sell your 727 and turn in your man card.
Re: Is it possible... bolt a 727 to a GM or Ford block? [Re: grncpe] #1073978
09/14/11 11:02 PM
09/14/11 11:02 PM
Where do you get that the C6 is better than a 727 I've had vehicle with both and we all know the C6 is the biggest power robber of all the modern 3 speed automatic, right above the Turbo 400 trans Chrysler got ir right when they designed the 727 BTW, I have seen turbo 400 and C6 blow up at the races, just like the 727, maybe worst
