64 Dodge #1073889
09/12/11 04:54 PM
09/12/11 04:54 PM
somewhere out there
Billy no mates Offline OP
somewhere out there
Guys,
Hope you can help I have a 64 Dodge with a 65 rear end which is out of the car at the moment hence the reason for my question. My question is will a 15 x 8" with a 4 1/4 back space work with 275/60/15 tyre without rubbing the wheel well opening?
thanks Billy
BillyNoMates
Re: 64 Dodge [Re: Billy no mates] #1073890
09/12/11 09:07 PM
09/12/11 09:07 PM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
I have the same tire and wheel with the stock rearend and it comes very close I have had it just lightly touch on a bump or turn I think the 65 rear end might be slightly shorter if it is should work perfect
Re: 64 Dodge [Re: polara426] #1073891
09/13/11 01:56 PM
09/13/11 01:56 PM
somewhere out there
somewhere out there
Hi,
Thanks for you reply. A 65 rear axle is 1" wider than a 64 axle, did you tyre rub on the wheel opening or spring?
thanks Billy
BillyNoMates
Re: 64 Dodge [Re: Billy no mates] #1073892
09/13/11 11:51 PM
09/13/11 11:51 PM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
Fender side lots of room inside
Re: 64 Dodge [Re: Billy no mates] #1073893
09/15/11 12:41 PM
09/15/11 12:41 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
I had 8.5" Torquethrusts on a 65 rearend in my 64 Polara with 275/60/15's and I had to keep the shocks aired up a little to keep the tires from rubbing the outter wheelwells. Rims had a 4" bs IIRC. I now have the same tires on a 10" rim with 5.5" bs and there's plenty of room on both sides of the tire to run the car level.
Jeff Adams 64 426 Polara
Re: 64 Dodge [Re: Ledman_70] #1073894
09/15/11 07:31 PM
09/15/11 07:31 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
I had a set of 15x8 wheel vintiques with 5.4" back spacing. Too close to the outer fender for me. From my measurements a 15x8 with 5.5 backspace would be great with up to a 10" wide tire. LOTS of room on the inside.
I ended up going with a 15x7 with 4.5"BS. Fits great with a 29" tall 8" wide tire.
very clever dinner. appetizing food fit neatly into interesting round pie.
