Re: High stall convertor burnout
[Re: joes68340s]
#1073861
09/12/11 03:40 PM
09/12/11 03:40 PM
Posts: 1,019 Finland
mafo
Finland
which gear ?
a 5000 rpm converter should spin the tires in water easily from 3 - 4000...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: joes68340s]
#1073862
09/12/11 03:40 PM
09/12/11 03:40 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
What gear are you in? I do my burnout in secound gear. Seems to get em spinning fairly fast. If you have really steep gears start in secound and go to third.
67' charger 499 RB
10.57 at 127
[Re: joes68340s]
#1073864
09/12/11 03:58 PM
09/12/11 03:58 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Are you using a line lock and just holding the brake pedal?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: joes68340s]
#1073866
09/12/11 04:44 PM
09/12/11 04:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Im starting in second gear shift into third. I run 4.88 gears.
I engage the line lock(pump the pedal a few times then hit the button)... I start in high gear with a 4.56 gear... give the gas pedal a good whack to start them spinning then watch the revs and I give it like a 3 count then let off the button and burn forwards till you want to quit... the deal is tire speed... faster makes more heat/smoke ![](/ubbthreads/images/graemlins/wave.gif)
[Re: joes68340s]
#1073868
09/12/11 06:15 PM
09/12/11 06:15 PM
MR_P_BODY
Drive through water not sitting in it. Pump brakes hit the lock, start in second shift third it hits 6000 hold about 5 sec release line lock roll out. Problem im having is there is no tire smoke.
Are they new or old tires... hold the burn out longer till they smoke some... you could be still too wet ![](/ubbthreads/images/graemlins/wave.gif)
[Re: joes68340s]
#1073870
09/12/11 07:03 PM
09/12/11 07:03 PM
MR_P_BODY
They are fairly new. I start to feel a bit of a shudder or vibration in rear when im doing the burnout.
They may be starting to bit... turn up the revs a bit higher ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Cab_Burge]
#1073874
09/13/11 10:12 AM
09/13/11 10:12 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
You need some video so you can see what is really going on. If you are really doing a burnout that long at that rpm with no smoke, there is a good chance something else is slipping.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: joes68340s]
#1073876
09/13/11 03:54 PM
09/13/11 03:54 PM
nhramark
Wheels up, MO
That's what the video of the burnout is for. Maybe you're not out of the water as far as you thought you were, maybe you're not holding rpm as long as you thought.
Burnouts are a relatively simple process and you seem to have something out of whack. It's a lot easier to figure things out when you can see them and hear them on video.
9.100 @ 150 mph
5.780 @ 120 mph
