Wiseco vs Daimond
#1073039
09/11/11 12:25 PM
09/11/11 12:25 PM
Posts: 1,532 off the grid
340B5
off the grid
I've never used Wiseco pistons, but they are 40+ grams lighter than their Diamond counterpart. Just looking for experience here. Anyone been hammering on Wiseco pistons for an extended time?
Are they lighter in the crown and hopefully not in the pin area?
Yeah, it's got a smallblock.
Re: Wiseco vs Daimond
[Re: Diablo]
#1073041
09/11/11 02:42 PM
09/11/11 02:42 PM
340B5
off the grid
Thank you; maybe this is one instance where light isn't always right.
[Re: stevet340]
#1073043
09/11/11 06:37 PM
09/11/11 06:37 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I've used Wiseco and been pleased.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1073044
09/11/11 08:36 PM
09/11/11 08:36 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Wisecos in the 416 stroker with 12.5 cr. So far so good. Many Wisecos in many dirtbikes. So far so good. Diamonds in the 528 hemi with 10.3 cr. So far so good.
Chris from New Jersey
[Re: fig426]
#1073045
09/12/11 12:35 AM
09/12/11 12:35 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
I have a set of wiseco's in my motor. I messed one up and need to buy a single piston but you can only get four as the smallest order.
Apparently Diamond will sell singles.
1974 Roadrunner
1967 Charger
[Re: Saskabusa]
#1073046
09/12/11 08:57 AM
09/12/11 08:57 AM
Posts: 339 western PA
stevet340
western PA
I don't think that is true as I have bought single pistons from wiseco before and have bought pistons in sets of ten so I had a spare left and right. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: stevet340]
#1073047
09/12/11 09:58 AM
09/12/11 09:58 AM
Posts: 20,703 in a cattle trailer down by th...
Guitar Jones
My experience is if you order custom pistons you can get them in any quantity you wish but not less than 4, if it's a shelf stock piston you can buy in singles regardless of the company but I've only dealt with Ross and Wiseco.
[Re: Guitar Jones]
#1073048
09/12/11 11:05 AM
09/12/11 11:05 AM
340B5
off the grid
Does anyone by chance, have a pic of the underside of a smallblock Wiseco piston?
[Re: 340B5]
#1073049
09/12/11 11:11 AM
09/12/11 11:11 AM
Guitar Jones
I've got Wisecos in my new short block but i don't think I have any pics of the underside. I'll look tonight when I get home if I remember.
[Re: Diablo]
#1073051
09/12/11 03:16 PM
09/12/11 03:16 PM
340B5
off the grid
I understand. Mine will be a Lt. Duty app. compared to what you're doing.
[Re: 340B5]
#1073054
09/13/11 01:54 PM
09/13/11 01:54 PM
Posts: 149 Cleveland Ohio
Discoquik
Cleveland Ohio
Assuming these are shelf stock, which parts are you looking at? ProTru or Wiseco? There are 408 stroker parts in both lines. Generally, shelf stock is actually rather heavy for what the parts are, because they are geared to withstand a fair amount of nitrous. The parts mentioned in this thread that cracked would have had to have been custom parts, which is almost always dictated by the customer what the thickness and "beefyness" of the part is to be. If a customer leaves that spec up to Wiseco it is always going to be built heavier than lighter, for obvious strength issues. If you want, shoot me an email and I can get you specs, and I can check to be sure what you are looking at is suitable for the application. The 8cc 408 pistons are on the shelf and ready to go in .984 and .927 pin configurations for both 340 and 360 applications. vellinger@wiseco.com
[Re: Discoquik]
#1073055
09/13/11 03:13 PM
09/13/11 03:13 PM
340B5
off the grid
I talked to Kieth @Wiseco a few months back. I believe it was Pro-true we were talking about. I will need a custom pin ht.between 1.487 and 1.500.(haven't decided yet)
[Re: Guitar Jones]
#1073056
09/13/11 08:40 PM
09/13/11 08:40 PM
Guitar Jones
OK sorry no pics of the underside.
[Re: Guitar Jones]
#1073058
09/13/11 10:39 PM
09/13/11 10:39 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Here are some pics of the new Wiseco small block dome pistons. Pictures didnt come out to good, but I think you can see good enough.
RIP Monte Smith
[Re: CompWedgeEngines]
#1073059
09/13/11 10:40 PM
09/13/11 10:40 PM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
#1073060
09/13/11 10:41 PM
09/13/11 10:41 PM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
#1073061
09/14/11 01:31 AM
09/14/11 01:31 AM
340B5
off the grid
Thanks for the pics, the pin area looks strong enough for me.
